Center tail light piece...making it light up
Old Mar 1, 2004 | 07:37 AM
subgeniusdude's Avatar
Default Center tail light piece...making it light up
I was behind a Cadillac Catera the other day and thought the tail lights were cool...the center piece was illuminated and that got me thinking about the center piece on Civics/CRX's.I was thinking about pulling it out and maybe seeing if I could get it to do the same...maybe some LED's spliced into the parking lights or something.The only problem would be pulling it off clean and OEM looking,anyone tryed this before?
Old Mar 1, 2004 | 07:59 AM
manson's Avatar
Default Re: Center tail light piece...making it light up (subgeniusdude)
i have an extra center piece. i haven't taken too much time to it, but i was planning on making an led housing for it so it can light up. i want it to illuminate CRX right in the center. thought that would be pretty neat.
there isn't too much space back there though...
Old Mar 1, 2004 | 08:42 AM
eric.'s Avatar
25 Year Member
Another CRXer did this years ago...
Here is the link.
http://home.houston.rr.com/crx...r.htm
Old Mar 1, 2004 | 08:43 AM
AgentJam's Avatar
Default Re: Center tail light piece...making it light up (mood)
i like the look of that
Vince
Old Mar 1, 2004 | 08:53 AM
BAZ's Avatar
BAZ
Default Re: Center tail light piece...making it light up (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">i like the look of that
Vince</TD></TR></TABLE>
Me too, night shots are key though.
Old Mar 1, 2004 | 09:30 AM
I3ackfire's Avatar
I have been thinking of doing something like this for a little while now, but having the whole center piece light up when I use my brakes.
This does look kinda of ricey but still kinda cool.
Old Mar 1, 2004 | 10:13 AM
Bleed Black's Avatar
Default Re: Center tail light piece...making it light up (I3ackfire)
http://www.2gnt.com/www/files/illuminatedtail.htm
I did this to my Eclipse like 5 years ago. I used this link to help me. Its for Eclipses but should work for the Hatch.
Old Mar 1, 2004 | 11:23 AM
AgentJam's Avatar
Default Re: Center tail light piece...making it light up (slowasshatch)
The pic in that link doesn't look as good as i would want it to on my car...is there anything out there that is very reflective, more than Foil? Maybe like flexible mirror type stuff they have at Pep Boys for when your side mirrors break...
I could only do this mod if mine came out perfect...but that's just me.
Vince
Old Mar 1, 2004 | 11:46 AM
R6Boy69's Avatar
I've got an extra 88-89 crx center peice if anyone wants to try this...
Old Mar 1, 2004 | 12:55 PM
EyelessCRX's Avatar
Some good drilling and splicing will easily do the trick. Be carefull not to hit the other side of the light when drilling through though. Also use rubber to insulate any wholes you drill.
Old Mar 1, 2004 | 05:16 PM
somethinwikd's Avatar
Default Re: Center tail light piece...making it light up (EyelessCRX)
there is a plexiglass mirror out on the market... all the sub enclosures that have the mirror on the inside... another thing you could use instead of the 6 volt bulbs or the clear gm dome lights that the guy in the eclipse used would be 2 of the little 4 inch white neon tubes... the transformers are built into the light so you could wire them up to the tail lights... and the neon will be a lot cooler as far as temp goes... if you wanted to you could add four of the neon tubes and hook 2 up to the break light... when you hit the break all 4 would light up and be that much brighter...just an idea... and in most cases the tep of the light wont melt the plastic on the honda parts... the paint on the eclipse version might burn but i dont think the plastic will melt...
Old Mar 1, 2004 | 07:19 PM
T-Mo's Avatar
I just read about a guy who did the leds in his center pc to make the "civic" light up
Old Mar 2, 2004 | 07:26 AM
BAZ's Avatar
BAZ
Default Re: (T-Mo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">I just read about a guy who did the leds in his center pc to make the "civic" light up
Thats an optional JDM piece I think
Old Mar 2, 2004 | 07:56 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (BAZ)
that eclipse looks like junk,u would need a strip of led's that went across the whole middle peice for it to light up fully.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ &raquo;</TD></TR><TR><TD CLASS="quote">
Thats an optional JDM piece I think</TD></TR></TABLE>
very rare, it also lights up green
Old Mar 2, 2004 | 08:01 AM
BAZ's Avatar
BAZ
Default Re: (Hybrid Hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">that eclipse looks like junk,u would need a strip of led's that went across the whole middle peice for it to light up fully.
very rare, it also lights up green</TD></TR></TABLE>
Was it an optional equipment piece in Japan, or standard equipment on a limited edition or what?
Old Mar 2, 2004 | 08:03 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (BAZ)
Was it an optional equipment piece in Japan, or standard equipment on a limited edition or what?</TD></TR></TABLE>
i think it was a option peice in Japan
Old Mar 2, 2004 | 08:15 AM
BAZ's Avatar
BAZ
They look soooo sweet. I wonder why they never had one for the CRX?
Old Mar 2, 2004 | 08:23 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (BAZ)
maybe there wasn't enough room in there for it, i know on the civic the light took up alot of room in it, and the crx has the reverse lights in the middle so it might have been a tight squeeze
Old Mar 2, 2004 | 08:30 AM
BAZ's Avatar
BAZ
Maybe. It just seems that the CRX would be the model that gets all the cool stuff since its the "sportier" of the two.
Old Mar 2, 2004 | 08:31 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (BAZ)
haha but its green....not really that 'sporty' lookin
Old Mar 2, 2004 | 08:39 AM
BAZ's Avatar
BAZ
Good call, it would look a little nicer in a different color like red maybe, still cool nevertheless.
Old Mar 2, 2004 | 12:01 PM
sleeperx's Avatar
Default Re: (BAZ)
I would recommend using bright red leds.. it will light it up with a nice red illumination and not make the point of light be as obvious as using a standard white bulb .. here is a great place to get your leds from .. high quality and cheap
http://www.superbrightleds.com
Old Mar 2, 2004 | 12:14 PM
AgentJam's Avatar
Default Re: (sleeperx)
aren't LED's more a direct beam rather than a flood of light?
Vince
Old Mar 2, 2004 | 12:37 PM
Default Re: (AgentJam)
thats why i suggested using the slim line neons... less than half an inch tall four inches long... and if you wanted to change the glow color just change the neon color... i would stick with white imo... but that is just me... they are cheap to get so you could play around with different colors to find what you are loking for...the led would be more like the progector affect... not an all around lighting type thing... you would have to line the whole piece with led's and that would get to be a lot... ever wonder how many led's are in the back of a spoiler/wing??? count em some time...
Old Mar 2, 2004 | 12:45 PM
xci_ed6's Avatar
I was thinking about it, and maybe EL glow panels, stick them right against the lens and it would make a nice even glow.
-Dustin
