Which Injectors for b18b TURBO????
I'm piecing together a kit similar to the revhard stage 2 kit. My goal is around 300 hp. What size injectors would I need and what brand, I have heard things about DSM 450 but I am not sure which ones to get, someone with good knowledge, let me know what injectors i'll need in my LS, thanks. I tried search, no good help.
i would actually go with 720cc injectors for you and leave room for improvement. running a 550cc will get you need s but the cost of 550cc are same as 720cc with good ecu control you should have no problems with the 720cc
ok, thanks, I'm looking for some 550cc RC saturated injectors, where can i get em cheap. I can't post in the classified section because i'm a "trial user" When will I be able to post there and how do I go about becomming a normal user???
You will be able to post in classifieds after your 15 day trial user period. RC 550's will be fine for your setup. You can get them from http://www.importparts.com ask for Ben or http://www.wiredspeed.com and ask for Kyle!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverb18 »</TD></TR><TR><TD CLASS="quote">ok, thanks, I'm looking for some 550cc RC saturated injectors, where can i get em cheap. I can't post in the classified section because i'm a "trial user" When will I be able to post there and how do I go about becomming a normal user???</TD></TR></TABLE>
WiredSpeed sells those RCs
http://www.wiredspeed.com/wire...p=&Bc=
