H22A, H22A1, H22A4 Cylnder heads
Old Mar 1, 2004 | 07:07 AM
Aaron.Hillman's Avatar
Default H22A, H22A1, H22A4 Cylnder heads
Is there a difference between ports or any other thing on these heads? Like on B and D series heads, they have differences in port shape and flow. I just had a H22A head and never seen a H22A1 or H22A4 to compare.
Old Mar 1, 2004 | 08:06 AM
LudeHatchH22a's Avatar
I am also interested, i have a h22a head, and have never seen a1 or a4 heads, but my guess would be that they are fairly close to the same, if not the h22a is better flow
so bump to get some info
Old Mar 1, 2004 | 08:47 AM
PirateMcFred's Avatar
Default Re: (LudeHatchH22a)
I know that the distributers are different for the JDM/OBDI/OBDII. I doubt that there are really that many differences in the castings, i.e. one really should not flow that much better than the other.
the Pirate.
Old Mar 1, 2004 | 08:52 AM
yellow_jacket's Avatar
Default Re: H22A, H22A1, H22A4 Cylnder heads (aahill69)
If you guys want, I'll post pics of my spare a4 head so you can compare.
Old Mar 1, 2004 | 02:39 PM
satan_srv's Avatar
Default Re: H22A, H22A1, H22A4 Cylnder heads (yellow_jacket)
I wouldn't expect much difference....considering the Intake manifolds are interchangeable, valves are the same, cc size is same...
Old Mar 1, 2004 | 02:44 PM
PrecisionH23a's Avatar
Does anyone have any flow bench charts/sheets of a stock H series head?
Old Mar 1, 2004 | 03:58 PM
ki11a8ee's Avatar
I know that the 97-up sh heads have a little more aggressive cams.
Old Mar 1, 2004 | 06:45 PM
satan_srv's Avatar
Default Re: H22A, H22A1, H22A4 Cylnder heads (ki11a8ee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee &raquo;</TD></TR><TR><TD CLASS="quote">I know that the 97-up sh heads have a little more aggressive cams.</TD></TR></TABLE>
wrong. same part numbers as a base.
Old Mar 1, 2004 | 06:47 PM
satan_srv's Avatar
Default Re: H22A, H22A1, H22A4 Cylnder heads (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have any flow bench charts/sheets of a stock H series head?</TD></TR></TABLE>
Keep in mind all benches are different
Old Mar 1, 2004 | 08:18 PM
alphajesse's Avatar
Default Re: H22A, H22A1, H22A4 Cylnder heads (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
wrong. same part numbers as a base.</TD></TR></TABLE>
Dunno about the part numbers, but according to my helms, the primary and secondary lobes are the same, but the middle lobes are different.
VTEC Lobe
Base SH
IN: 36.856 37.229
EX: 36.323 36.704
The valve spring free lengths are different, too.
Base 1 Base 2 SH
IN
outer 45.16 45.76 40.01
inner 41.78 41.75 43.61
EX
outer 46.72 46.74 44.58
inner 39.32 39.28 41.07
Of course, the helms also fails to mention the differences in the cranks between 97 and 98-on cars, and just lists every H22 as having 50mm mains.
EG6 Master
Feb 18, 2013 10:59 PM
mozzandherb
Jun 22, 2011 07:55 AM
kornkid21792
Aug 6, 2009 05:23 PM
