Integra Engines
Im new here and Im looking at getting a used Integra, maybe a 96 or 97.
My limit is around $6500.
The different models are:
LS
RS
GS
GSR
Type R
Correct?
So whats the differences in these engines, I know some of its HP but a couple of these engines have the same HP, so whats the other differences? Also, did the engines change over the years?
Could someone please help me out with my confusion between these engines, I want to know what im getting when I buy it.
Thanks
LS
RS
GS
GSR
Type R
Correct?
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CK9887 »</TD></TR><TR><TD CLASS="quote">Im new here and Im looking at getting a used Integra, maybe a 96 or 97.
LS
RS
GS
GSR
Type R
Correct?
Thanks</TD></TR></TABLE>
for $6500 you could get yourself a nice gsr motor.
LS
RS
GS
GSR
Type R
Correct?
yeah and what car is he going to put the engine in???
for the amount your looking to spend, you could get a high mileage gsr or a newer rs/ls/gs. depends on what you want.
some specs on engines
B18B1 140hp@6300 128lbs-ft@5200 redline 6800
B18C1 170hp@7600 124lbs-ft@6200 redline 8100
B18C5 195hp@8000 130lbs-ft@7000 redline 8400
the only change the engines really went through was their ecu,
92-93 obd0
94-95 obd1
96-01 obd2
the type R is the top of the line integra by far, but is way out of your price range, the GSR comes with the vtec engine and some good suspension and cosmetic differences than the LS/GS/RS.
Modified by trix121 at 4:28 PM 3/1/2004
92-93 obd0
94-95 obd1
96-01 obd2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trix121 »</TD></TR><TR><TD CLASS="quote"> 94-95 obd1 Modified by trix121 at 4:28 PM 3/1/2004</TD></TR></TABLE>
actually 92-95 was obd1
http://69.53.28.141/specifications.html
look on there, the site has all the info on the 3rd gen integra!
By a high mileage ls or gsr cheap. More than likely the Ls will be cheaper. Take the rest of the money for a bottom end build up. Or, take the rest of the money for a turbo kit, even if you have to add some more money to it. Just my 2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x »</TD></TR><TR><TD CLASS="quote">i got my 95 gsr for 4500 and i love it for 6500 you could probly find like a 96,97 gsr thats what i would do</TD></TR></TABLE>
nahhh stick with 95 GSR or 94 they are OBD-I
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">well to start you off:
RS, LS, GS = B18B1
^non-vtec
GSR/B18C1 + ITR/B18C5
^vtec
i believe the 94-97 are b18b/pr4 and the 98-up are b18b/p75. thats a pretty big differance but not really. the p75 head/im flows better. i agree with 94-95 gsr with low milage is best car to start off with unless you get a type r.
RS, LS, GS = B18B1
^non-vtec
^vtec
jweezy225
Feb 1, 2004 07:19 PM
