Help with H23A1 USDM To H22A JDM Swap
Old Feb 29, 2004 | 11:23 PM
[mmm]PFM's Avatar
Default Help with H23A1 USDM To H22A JDM Swap
Whats up Fellas Need alittle help with my new swap.
H23A1 Usdm to H22A VTEC JDM
I talked to a Guy named Lee Nash and he told me the H23 wiring harness will function the same as the H22 wiring harness, but you have got to add 3 wires in order to get VTEC and everything working properly.
He told me these:
1. VTEC Solenoid
2. Oil Pressure Wire
3. He forgot
Are those right if they arent Could someone help me find these specific wires so I can have friggin VTEC and have my car running properly?
Another thing, my H23 computer is plugged in right now, and the D4 Light is blinking [I have an automatic] - Could this indicate my computer is the wrong one?
Im not too good with trouble codes - and a few people have told me it is a problem with the transmission?? If anyone is familiar with that please let me know, another thing: when my H22 computer is plugged in, it idles rough and turns off. If someone is familiar with that as well please post with your knowledge.
Tell me everything that you may know about the complications of this particular swap.
Thank you Fellow Lude Users,
-PFM
Old Mar 1, 2004 | 07:35 AM
DW's Avatar
DW
Default Re: Help with H23A1 USDM To H22A JDM Swap ([mmm]PFM)
vtec solenoid (green with yellow stripe)
vtec oil pressure switch (blue with black stripe?)
pressure switch ground (black)
as for the tranny light blinking...that means you have something wrong with the transmission. i dont know too much about that but you will have to get an auto p13 ecu for the swap to work....unless your swaping out the auto too
David
Old Mar 1, 2004 | 08:22 AM
Honda Sport's Avatar
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
I have an auto JDM p13 ECU if you need one. PM me if your interested.
duceducecord
Apr 8, 2007 02:56 PM
NobodysHero
Apr 6, 2004 02:43 PM
shadowludeJDM
Mar 29, 2004 09:07 AM
TruNinja619
Mar 7, 2004 10:03 PM
