Is it an ITR front brake setup or +97 5th gen Prelude?.....
Old Feb 29, 2004 | 10:40 PM
808dc2's Avatar
Default Is it an ITR front brake setup or +97 5th gen Prelude?.....
Please Help!
I picked up front 5 lug brakes from a friend who told me they are ITR but he's not 100% sure. They could either be JDM ITR or +97 5th Gen. Prelude. How can I be sure which one it is???
thanks in advance!
Old Feb 29, 2004 | 10:54 PM
^jefs0ng's Avatar
Banned
Shouldn't you have asked this before you bought em? I heard the prelude vtec and ITR were the same so I wouldn't be too worried.
Old Feb 29, 2004 | 10:58 PM
808dc2's Avatar
Default Re: Is it an ITR front brake setup or +97 5th gen Prelude?..... (808dc2)
I got them for free. But If they wont fit I will need to order the front only since I already have the back setup.
Anyway, the calipers and rotors I think are the same but I dont know if the knuckle will fit or not. I cannot use my stock GSR knuckle because the hub is a 36mm which means the setup either came from a JDM ITR or +97 5th gen. prelude.
Old Feb 29, 2004 | 11:33 PM
808dc2's Avatar
can a 5th gen front brake setup bolt on to a DC2 while still using the knuckle setup?
Old Sep 30, 2004 | 01:04 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808dc2 &raquo;</TD></TR><TR><TD CLASS="quote">can a 5th gen front brake setup bolt on to a DC2 while still using the knuckle setup? </TD></TR></TABLE>
same thing i'm trying to find out basically.. are the calipers the same for an ITR and a prelude? or does it all mount differently?
Old Sep 30, 2004 | 01:22 PM
B18C5's Avatar
Default Re: Is it an ITR front brake setup or +97 5th gen Prelude?..... (mstewar)
The calipers are the same, but the mounting plate thing is different. If you try and use the mount from a Prelude the caliper will rub on one side. If you reuse the ITR mount everything else is identical.
You should be able to machine the plate or maybe use a small spacer if you have to.
es_squared
May 27, 2007 03:29 PM
aram005
Dec 15, 2005 08:00 PM
thehondaguru
Sep 8, 2003 06:21 PM
SimbaDogg
Mar 28, 2003 03:08 PM
