45+offset & 205-50-15r tires on a civic????
i searched and cant find anything related. I got a set of kosei wheel 15x7 with a 45+offset for a good price. now i went to test fit and the are like 1/2 in or maybe even closer to the front forks( i think thats the name
) im thinking that if i use tires that are 205 i might rub there. also should i be trippin about it being so close as is ????possible grinding????maybe some wheel spacers should solve this issue or just sell the wheels>? thanks i hope to get some responses.
For a 7 inch wide rim people usally go for +40, +41 or +42. I would get some extended wheel studs and a 5mm spacer.
What are the wheels coming off of? miata?
well the rims were off a 96 civic ex. they currently got 195-50-15r tires but i want to throw on some azenis i got. how much should i look into spending for the extended lugs, spacer and all that to make them work??can i get a smaller spacer for now jsut for the 195 series tires and use stock lugs, or should i be fine till i get the wider tires?
Well sence they are coming off of a honda you know they fit. I would install them and see how much clearance you have. then go from there if you want to upgrade to a wider tire.
extended studs/spacer kit run about $60 for a pair. You may need open ended lug nuts too wich is more $$
i think they shoud fit, well thats what i thought tell i saw that you were wanting to run azens, they are alot wider then they say on the side wall let me see if i can find the thread that dpects it. i say throw it on and find out should work though.
https://honda-tech.com/zerothread?id=163023
there is a good one non of the pics work for me though
Modified by slammed_93_hatch at 3:31 AM 3/2/2004
Nunya Buidness
Honda Civic (2001 - 2005)
Nov 14, 2018 10:43 AM
redlineintegra
Jun 5, 2006 06:27 AM
Dr Pooface
Jun 10, 2002 07:32 PM
