better understanding after researching limp mode, but still need help???
Old Feb 29, 2004 | 07:56 PM
MysteryWagon's Avatar
Default better understanding after researching limp mode, but still need help???
lsvtec not running knocksensor, but waiting on chipped ecu to get back.
I was reading that limp mode will not let you go above 2500rpm, is this true?
2nd, I have made it to 4600 rpm. any ideas?
3rd, while running with the code 23 knocksensor, will it make car run slugish or put it into a state like limp mode?
when getting rpm up around 4600 slightly leans out, yet this is a very unacurate A/F gauge just as a slight precausion, no harm in that right ?
thanks alot
Justin
Old Feb 29, 2004 | 07:59 PM
boostn420's Avatar
Default Re: better understanding after researching limp mode, but still need help??? (MysteryWagon)
There are different limp modes. Sometimes it wont rev over 3000 rpm other times it just goes super rich. Lean is bad usually with a knock sensor fault it should go rich, most likely the gauge is wrong.
Old Mar 1, 2004 | 03:55 PM
Default Re: better understanding after researching limp mode, but still need help??? (boostn420)
i hope, it could also have to do with me not being able to tune it until knock sensor situatuion is fixed
vtec92accord
Aug 16, 2008 08:09 AM
Mike36
Dec 18, 2006 08:19 PM
lshatch92
Feb 19, 2006 10:51 PM
lshatch92
Feb 13, 2006 06:34 AM
integRated109
Jul 5, 2002 02:02 PM
