Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Tuner Toys: Oil fittings, Drain Flanges, and Oil Line Kits for your Turbo!
Old Feb 29, 2004 | 06:37 PM
TunerToys's Avatar
Default Tuner Toys: *NEW* Fuel Injectiors, Oil fittings, Drain Flanges, and Oil Line Kits for your Turbo!
<FONT SIZE="3"><u>*NEW* Correct Inject Fuel Injectors</u></FONT>
- No more need to gamble on used DSM injectors.
- No more need to pay a fortune to RC Engineering.
- No need to put a spikey FMU on your car.
- No more hacking your loom to put in a resistor box.
Tuner Toys now offers fuel injectors that flow 450cc on the stock fuel pump, and are an exact physical match for the OEM Honda Injectors. No more hogging out seals and cramming the wrong sized injectors into your Honda. You can now buy brand new 450cc Injectors in high or low impedance styles. No more resistor boxes!
All Injector sets are match flowed to within 1%, and come with a one year free replacement warranty.
Shipping for one set of injectors is $5.75 to any address in the US, plus $4.50 for $250 Insurance.
Buy this item now - CorrectInject Sets at Tuner Toys
<FONT SIZE="3"><u>Oil Take Off Fittings</u></FONT>
TunerToys offers a great solution for getting oil for your turbo. Our tee fitting installs between the factory oil pressure switch, and the engine block. Depending on the style purchased, one or two oil ports are provided for supplying oil to your turbo, gauge, or VTEC activation. It has the correct BSP and NPT threads in the proper locations, which means no more cramming a NPT fitting into your BSP threaded oil port, or having to use a BSP to NPT adapter.
This is the best solution we have found for supplying oil to your turbo or gauges.
Buy this item now - Oil Fittings at Tuner Toys
Shipping for up to three oil fittings is $3.85 to the US.
<FONT SIZE="3">T25 Oil Drain Flange Kit $13.99 (+$3.85 Shipping)</FONT>
Click here for a larger image...
The T25 Style flange fits most oil drains with a 44mm bolt spacing. Examples of these turbos are the Garrett standard T2/25/28 Turbochargers. Included hardware includes M8-1.25 Socket Head screws (which exceed Grade 8 Specifications), and lock washers. Gaskets are sourced from approved Garrett distributors.
Click here to purchase from our online store now!
<FONT SIZE="3">T3/T4 Oil Drain Flange Kit $14.99 (+$3.85 Shipping)</FONT>
The T3/T4 Style flange fits most oil drains with a 50.8mm bolt spacing. Examples of these turbos are the Garrett T3/4/4S & GT32/35/37/40 Turbochargers. Included hardware includes M8-1.25 Socket Head screws (which exceed Grade 8 Specifications), and lock washers. Gaskets are sourced from approved Garrett distributors.
<FONT SIZE="3">Complete Oil Line kits - $90 Shipped</FONT>
We are proud to offer the Stealthmode Performance Oil Line Kits!
Each kit includes a complete oil feed and oil drain solution for your turbo project. This oil feed portion of the kit uses a Tuner Toys block fitting and -4 stainless steel line (3ft), and a -4 to turbo oil inlet adapter. The drain consists of a Tuner Toys oil drain flange with a barbed fitting connecting the drain flange to the -10 stainless drain hose (14"). We use a barbed fitting on the lower end for the pan as well. The kit comes with everything you see in the picture above.
PLEASE SPECIFY WHAT TURBO YOU ARE USING WHEN ORDERING! We need this information to provide you with the proper -4AN to turbo oil inlet adapter.
We also offer the Stealthmode Performance LS/VTEC kits ($50 Shipped), and their braided steel fuel line kits($50 Shipped). Send us an email at sales@tunertoys.com if you want more info about these products!
<FONT SIZE="3">We now offer Golden Eagle Products!</FONT>
<FONT SIZE="3">Golden Eagle Vacuum Manifold</FONT>
Golden Eagle Manufacturing's Vacuum Manifolds are specifically designed for turbo charged engines that require multiple vacuum sources.
Every manifold is constructed of CNC machined 6061-T6 aluminum. The six (6) usable ports can be used for items such as fuel pressure regulator, blow-off valve, MAP sensor, boost controller, boost gauge and any other engine component that requires a vacuum source.
Installation instructions and mounting hardware are included with every manifold.
We are offering them at the low price of $31.10!
Modified by TunerToys at 2:20 AM 5/16/2004
Old Feb 29, 2004 | 07:12 PM
Smokinsax's Avatar
The Boot
wow...deff looking into this!
Old Mar 1, 2004 | 05:50 PM
TunerToys's Avatar
Default Re: (Smokinsax)
Thanks! Let us know if you have any questions!
Old Mar 1, 2004 | 05:57 PM
Smokinsax's Avatar
The Boot
pm'd
Old Mar 2, 2004 | 05:38 PM
TunerToys's Avatar
Replied. Thanks for your interest!
Old Mar 3, 2004 | 08:23 PM
ASHY-ELBOW's Avatar
Default Re: (TunerToys)
nice fitting , ordered one a while back for my friends car, worked great and service was
Old Mar 6, 2004 | 11:16 AM
mikecivichb's Avatar
I looked on your web site for ordering the oil line kit. But i could find it.
Old Mar 7, 2004 | 01:06 PM
TunerToys's Avatar
Default Re: (mikecivichb)
Sorry about that!
We are waiting on better pictures before we add the oil line kits to our website.
You can order direct from us by sending an email to "sales@tunertoys.com" or a $90 Paypal payment to the same name (our email is the same as our Paypal account name).
We'll need to know your engine and turbo application to fill the order, so be sure to let us know!
Thanks from Craig at Tuner Toys
Modified by TunerToys at 10:25 AM 3/31/2004
Old Mar 8, 2004 | 07:03 AM
GimpyAccord's Avatar
Bump for some good guys, TunerToys & Stealthmode is who made my Home Made Turbo possible. There are tons of ways to get oil in and out of a turbo, but their products are the best... trust me.
Old Mar 14, 2004 | 09:18 PM
TunerToys's Avatar
Default Re: (GimpyAccord)
Thanks for the good words! The Golden Eagle manifolds have been selling like crazy! Feel free to email us with other items you guys would like to see us add to our product line!
Craig at TunerToys
Old Mar 16, 2004 | 08:21 AM
dc-lefty's Avatar
pm s ent
Old Mar 16, 2004 | 08:18 PM
SOHC_MShue's Avatar
Default Re: Tuner Toys: Oil fittings, Drain Flanges, and Oil Line Kits for your Turbo! (TunerToys)
That vacuum manifold is pretty nifty
Old Mar 21, 2004 | 05:48 PM
turtle-eg's Avatar
Is it $80 or is it $90 for the turbo oil line kit? I was about to paypal 80 over for the lines, but thought I should ask first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerToys &raquo;</TD></TR><TR><TD CLASS="quote">Sorry about that!
You can order direct from us by sending an email to "sales@tunertoys.com" or a $80 Paypal payment to the same name (our email is the same as our Paypal account name).
Thanks from Craig at Tuner Toys</TD></TR></TABLE>
Old Mar 24, 2004 | 05:18 AM
ykracing's Avatar
Default Re: (turtle-eg)
lets say that I NEED a t3/4 drain flange, how quickly can it get here?
also, what thread is the drain flange, 1/2 pipe?
lmk
Old Mar 25, 2004 | 09:14 AM
turbo*s2k's Avatar
Default Re: (trboCIVICWRX)
I won something on ebay from them about a week ago. I received the item pretty quick and they sent me tracking infomation!
Thanks!
Old Mar 28, 2004 | 09:31 PM
Sho Pow's Avatar
Great Seller and great products. I have the stealthmode oil lines with all the tuner toys fittings. Great stuff.
Old Mar 29, 2004 | 01:22 PM
boosted jetta's Avatar
Default Re: (Sho Pow)
i just ordered an oil drain flange , great price
Old Mar 30, 2004 | 07:38 AM
khoalie's Avatar
Default Re: (boosted jetta)
bump for good product
gonna be ordering mine soon
Old Mar 30, 2004 | 04:09 PM
SleepyEG's Avatar
Default Re: (khoalie)
great stuff!
Modified by SleepyEG at 12:50 AM 3/31/2004
Old Apr 1, 2004 | 06:36 AM
SleepyEG's Avatar
Default Re: (SleepyEG)
ordered a kit from craig. very helpful people and great products!
Old Apr 5, 2004 | 09:08 AM
got my oil drain flange kit and it didn't fit my innovative turbo, the bolts were to small, the just slid in and out of the holes so i found some bolt that fit but then i had to drill the holes in the flange bigger and grind some of the flange away, just letting you know that these don;t fit innovative turbos
Old Apr 6, 2004 | 09:35 PM
playAho's Avatar
bump so I can order later!
Old Apr 7, 2004 | 12:44 PM
jl2teg's Avatar
Default Re: (playAho)
how much for just an oil return line kit (ss)
Old Apr 8, 2004 | 07:17 PM
frcefed98's Avatar
Craig, Sent you an email on the Golden Eagle Polished Vacuum Manifold that I ordered from you last week. When should the UPS man be dropping this off.
Thanks,
JB
Old Apr 9, 2004 | 08:23 PM
tobyboom's Avatar
Are the prices still good on the Golden eagle Vacumm manifolds? $29.90
