gsr work with b16a1 ecu?
Old Feb 29, 2004 | 05:42 PM
b18crxjrsc's Avatar
Default gsr work with b16a1 ecu?
i have a obd0 91 integtra and am putting a 94 b18c1 engine in it, i have a b16a1 ecu and was wondering if it would run good with this ecu?
Old Feb 29, 2004 | 08:16 PM
eyeamvic's Avatar
No. Try to find a GSR ECU or at least get an ECU chipped with the GSR fuel/ignition curves.
Old Mar 9, 2004 | 03:43 AM
jrcrx's Avatar
Default Re: gsr work with b16a1 ecu? (b18crxjrsc)
I was wondering if you want to sell theb16a1 ecu. E-mail me at jrcrx76@yahoo.com
Old Mar 9, 2004 | 02:56 PM
iH8RICERZ's Avatar
Yes the b16a ecu will work and run your motor....not perfect, but it'll do the job until you can find a gsr ecu to run.....you may have to get an obd 0-1 conversion harness and run a 94-95 GSR p72 ecu.....
Old Mar 9, 2004 | 03:01 PM
3.504's Avatar
Default Re: gsr work with b16a1 ecu? (iH8RICERZ)
get a obd0-obd1 conversion harness and a p72.... if you dont wanna do that... you have to run obd0 distributor and i'd get a new intake mani cause the gsr mani wont have the secondary runner control w/ the pr3 you're using... if anything i'd swap the mani, get the obd0-obd1 conversion harness, get a hondata and a chipped p28 then call it a day
Old Mar 9, 2004 | 03:06 PM
Kataku2K3's Avatar
Default Re: gsr work with b16a1 ecu? (3.504)
As others have said the PR3 or PW0 will work just fine tho it won't have IAB control (not that it really matters because if you simply pull the vacuum line off the control diaphram solenoid, the IAB's will always be open)... The easiest route is to just do that or swap manifolds and run a nonOBD ECU. If you want to do an OBDI conversion I would recommend a chipped P28, if you're motor is staying relatively stock there's no reason to run Hondata. The GSR (P72) ECU's VTEC is too low and the mapping is **** making it come last in my book (as I've said numerous times). Good Luck
DA STRIKER
Feb 4, 2011 03:49 PM
ef2hondaboi
Jun 23, 2009 04:33 PM
tmar253
Nov 28, 2006 09:39 PM
Renegade
Aug 29, 2003 09:17 AM
