Removing the rear motor mount on a 90 Si
I'm recasting my motor mounts in urethane.
I have three of four done, but the back mount is a real bitch.
Has anyone actually removed the rear mount from the crossmember? Is there a bolt behind the mount that I won't be able to get to?
Any help appreciated.
John
John
There is a bolt behind the mount. Best way is to unbolt your rear crossmember and pull down on it. It wont come down very much, so you might have to have someone help you. Try a wobble and an extension to get back there. When you are ready to replace it. Slot the rear hole on the mount and put the bolt in the crossmember first, just a few threads, then slide the mount on. HTH
endo617
11
Jun 28, 2008 12:18 AM
Texas Civic
Jan 13, 2004 01:57 PM
