d15bvtec...2 stage or 3 stage
Old Feb 29, 2004 | 04:07 PM
pimp civic's Avatar
Default d15bvtec...2 stage or 3 stage
hi every body a d15bvtec 93 is it a 2 stage or 3stage..
im using a ecu p28??
Old Mar 1, 2004 | 06:52 AM
suspendedHatch's Avatar
Default Re: d15bvtec...2 stage or 3 stage (pimp civic)
There are generations of that engine all the way from the old CRX (sucky gutless engine), to the 5th gen which is the most common, to the 6th gen. The 6th gen is the only 3 stage VTEC. The 5th gen which you probably have is basically like a Z6 head on a D15, ie a factory mini-me.
One way to know for sure is to see whether there is one or two VTEC solenoids. If there are two, then you scored. Either way the max hp will be the same but the 3 stage will be faster and get better mileage.
Old Mar 1, 2004 | 08:02 AM
pimp civic's Avatar
Default Re: d15bvtec...2 stage or 3 stage (shaundrake)
there is only one vtec seloniode on my d15bvtec so it means its like a z6?
because i know somebody who wants to sale a perform cam from a z6 and want to know if it fit on my d15bvtec?
thx
Old Mar 1, 2004 | 01:01 PM
pimp civic's Avatar
Old Mar 1, 2004 | 01:05 PM
slammed_93_hatch's Avatar
what year is the motor. if its an obdI motor. aka if its from 92-95. then its the d15b vtec that is comparable to the z6.
i wouldn't suggest buying the cam. as the d15b vtec mention above has a more agressive cam then the z6 and i haven't seen a cam that is worth the money.
ie. yes after market cam would add hp but its minimal and shitty for a cam
Old Mar 1, 2004 | 02:32 PM
pimp civic's Avatar
Default Re: d15bvtec...2 stage or 3 stage (slammed_93_hatch)
does the after market cam from a z6 does it fit on a d15bvtec?
and yeah its a 93 obd1
Old Mar 1, 2004 | 02:37 PM
YES they are the sam cast head. its just it has a diffent cam in it. again i wouldn't swap out the cam unless you can find some specifics on the after market cam
thaknee
Nov 28, 2006 01:57 PM
SupraRXZ
15
Oct 30, 2006 05:55 PM
craigie
Jan 16, 2006 01:33 PM
prelude760
Jul 25, 2005 11:48 AM
an2ny888
23
Apr 24, 2004 05:57 AM
