brakes = no power?
Old Feb 29, 2004 | 02:32 PM
self_made's Avatar
Default brakes = no power?
My car used to be turbo'd, I was running 450's with a safc. I didnt like the way it was running, so I took off the turbo, put back in the stock injectors, took off the safc. A little before i took out all the stuff, everytime I would hit the brakes, the dash/radio would lose power. the temp/gas guages dim, the tach and speedo go down to zero, the radio turns off...its been driving me nuts latley. anyone have any idea at what it could be? thanks
Old Mar 2, 2004 | 12:54 AM
self_made's Avatar
Default Re: brakes = no power? (VTECNLUDE)
anyone?
Old Mar 2, 2004 | 01:55 AM
OTT's Avatar
OTT
So did the car stall at that point or stutter to run?
and did the lights go completely out?
do you have abs?
Old Mar 2, 2004 | 10:50 AM
self_made's Avatar
Default Re: (OTT)
it doesnt sputter or turn off, lights just dim out, sometimes they turn off completely. and yeh, i do have abs, and my abs light has been on for quite sometime..
Old Mar 7, 2004 | 04:53 PM
self_made's Avatar
Default Re: (VTECNLUDE)
ok, I have an update on this..whenever i turn on the headlights, the car stutters and shuts off..when i press the brakes, the dashlights turn off completely. also the tach nor speedo works. I check the battery and alternator, they're both good. check the stop light switch, wasnt that either, any help here?
Old Mar 7, 2004 | 11:32 PM
prelude-bb3's Avatar
i found out turning ignition key turning my radio off,when going to ACC...this wasnt before ,maybe the ignition key has a malfunction?
i heard it befor ebut im not sure..
EL TYPE R
Dec 22, 2016 12:28 PM
gsr-2nr
Nov 16, 2008 07:16 PM
self_made
Mar 7, 2004 04:54 PM
Mike813
Jul 20, 2003 03:04 PM
