not so torquey
Old Feb 29, 2004 | 02:25 PM
fergy016's Avatar
Default not so torquey
my friend just picked up a
a.) 92 prelude si, would the vin # tell me what engine was in it stock?
- it now has a vtec head and '99 jdm h22a block.
b.)should redline be about 6500rpm?
-noticed it had a p13 ecu in it.
c.)how to tell if ecu is obd 1(92-95) or obd 2(96-...)?
d.)are there #'s or specific things on the head to tell which gen the head came from?
I can get pictures, just need to know of what!
Old Feb 29, 2004 | 02:44 PM
PetroGuyX's Avatar
look under the hood and look for the engine code, if it's a 92 si it'll most likely say h23a1 and if it has a h22 block it would say h22a1 and redline for an h23 is 6500 so i'd say it's safe to say your buddy has an h23
Old Feb 29, 2004 | 02:45 PM
fergy016's Avatar
Default Re: (PetroGuyX)
naw it came with a swap, just trying to figure out which head was bolted onto the block. it says h22a on the block, and I got the info from the owner that it is a 1999 jdm block.
Old Feb 29, 2004 | 03:02 PM
JG Luder's Avatar
Default Re: not so torquey (fergy016)
a. yes
b. no
c. couldn't tell ya
d. never paid attention. To me an h22 head is an h22 head.
Old Feb 29, 2004 | 03:05 PM
fergy016's Avatar
Default Re: not so torquey (Lone Luder)
yeah but the dizzy will be different I believe making obd1/obd2/obd3 needed.
Old Feb 29, 2004 | 03:06 PM
fergy016's Avatar
o have driven the car, vtec kicks in, via the setting on the vafc. there is a vtec ecu just don't know obd1 or 2 so I don't know if I should suggest him getting a p28 and chip it because it has to be obd1 to do that.
Old Feb 29, 2004 | 03:49 PM
tylek17's Avatar
p13 is obd 1
Old Feb 29, 2004 | 07:15 PM
Behan's Avatar
Default Re: (tylek17)
no, a p13 from a 96 will be obd2. if you can post pics of the stickers on the ecu someone should be able to tell you if its obd2.
4gnhatch
Jan 17, 2021 01:07 PM
Baodalazi
Mar 29, 2008 05:11 PM
skylude23
May 27, 2005 04:29 AM
0ptimus prime
Apr 25, 2003 07:19 AM
94h23si
Aug 30, 2001 11:22 AM
