put yourself in my shoes..IDEAS PLEASE!!!!!!
91 civic hatch si with stock b16a..you have 1400 in cash..what would you get??
ive got intake,exhaust,kybshocks with eibach springs,6 puck stage 4 clutch
im looking for engine modds only..
im thinking msd ignition,crank pulley and ??? let me know
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 »</TD></TR><TR><TD CLASS="quote">FI?</TD></TR></TABLE>
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 »</TD></TR><TR><TD CLASS="quote">msd ignition</TD></TR></TABLE>
no...makes your idle nice though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 »</TD></TR><TR><TD CLASS="quote">crank pulley</TD></TR></TABLE>
no...from what ive heard youll be rebuilding soon after
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 »</TD></TR><TR><TD CLASS="quote">who makes a good t/b that doesnt cost an arm/leg</TD></TR></TABLE>
honda makes some nice 60 and 62mm TBs that are a good increase on your 58mm one. since i assume that $1400 means staying NA. stay away from the bling and go for the upgrades that give you the most bang for the buck.
i would get ctr cams, vtec controller, race enginering rebuild kit
or ctr cams vtec controller and NITROUS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Screw you guys, I'm... going... home.
Forget the crank pulley and ignition. Crank pulleys cause a lot of problems and stock honda ignition is really good stuff. If you're going to stay N/A there's not really much more you can do besides maybe cams, tb, and ecu. If it were me and I had $1400 to play with I'd probably build a homemade turbo setup or invest in some really good tires and wheels (i.e. not bling)
if i were to squeeze as much as i can out of 1600.
ported head, valve springs and retainers, and 3 angle valve job, milled head, with new headgasket.
Ctr intake cam, with gsr exhaust.
all which could be done if u do some shopping around, and get the cam used.
Try the EF1 valvetrain.
If had to spend money on my b16 again I'd sell my ITR valvetrain and try the EF1 valvetrain.
You can get the FULL valvetrain for 990$.. that's cams/springs/retainers. Then you have money left over for some ECU chipping or a VAFC. Maybe some CAM gears to go with the cams!
990=Valvetrain
150=Used/ Cam gears (I just bought new STR gears for 140$!!!)
That's 1140 then you have 260$ left over for other stuff including fuel management.
edit: ef1 website= http://m24x.com/
990=Valvetrain
i agree with ever one above me and soon below me but hey if you wanted rims i got some center line rpm's 18x7.5 with parada spec 2 tires 1200 shiped over 2grand in them used about 3 months 95%treed color black pearl 13.4lbs let me know jdmcivic6963@yahoo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 »</TD></TR><TR><TD CLASS="quote">i was thinking on type r cams/valve springs..
who makes a good t/b that doesnt cost an arm/leg? </TD></TR></TABLE>
Rocket Motorsports has M20 regrinds that are more agressive than Skunk2 stage 1 cams, but less than Stage two cams that need higher comression than the B16 has to work right. And at half the price of skunk. And Skunk stage ones are far more agressive than CTR or ITR cams.
