How to adjust handbrake?
Old Feb 29, 2004 | 11:57 AM
civickid03's Avatar
Default How to adjust handbrake?
I was wondering how to adjust a handbrake on an 03' civic. Do I need to take off the handbrake housing? There is nothing to adjust underneath the car. Anyone have a diagram?
Old Feb 29, 2004 | 12:02 PM
sohcvtec1995's Avatar
Default Re: How to adjust handbrake? (civickid03)
you just pop the caseing around the e-bbrake off, and there will be the cables with a bolt on it, you just tighten or loosen it like that.
Old Feb 29, 2004 | 12:09 PM
JayDeeEm's Avatar
I know what your trying to do, i suggest not doing it at ALL, if you tighten the e-brake past stock specification it could end up being partially engaged at all times, if you do decide to go through with it, be carefull in the amount you tighten the cable.
Old Feb 29, 2004 | 12:30 PM
CleanHatch's Avatar
Default Re: How to adjust handbrake? (JayDeeEm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeEm &raquo;</TD></TR><TR><TD CLASS="quote">I know what your trying to do, i suggest not doing it at ALL, if you tighten the e-brake past stock specification it could end up being partially engaged at all times, if you do decide to go through with it, be carefull in the amount you tighten the cable.</TD></TR></TABLE>
what is he trying to do?
Old Feb 29, 2004 | 12:48 PM
skip.two's Avatar
Default Re: How to adjust handbrake? (CleanHatch)
i don't understand what he's trying to do either.
Old Feb 29, 2004 | 02:32 PM
idumpwitmy12gaugepump's Avatar
Default Re: How to adjust handbrake? (jL iLLuZiOnz 9)
His ebrake is probably too high. I bet he wants it lower, thats what i did.
Bikewhorder
Mar 5, 2019 09:13 PM
bee20_vtec
Nov 3, 2008 03:07 PM
black0hatch
Dec 18, 2007 07:06 PM
Declectic
Nov 23, 2004 02:10 PM
Traction
10
Aug 24, 2004 01:36 PM
