zc diff
im puting in a si counter shaft and ring gear with a hf 5th in my zc trans and found out when i got out the diff that the pass side bearing is burnt up. it has a hot spot and i can HEAR it when i spin it. is it the same as the si dx. i dont have any manuels, but i im getting torque specs from aldata.
point would the usdm 1st gen teg diff have the same bearing? bc bigger drive shafts are needed to use it. meaning bigger bearings
Art T. Fish L.
23
Apr 6, 2002 09:27 AM
