Having idle problems with recent swap. Please help
I recently put a b16a in my 89 crx. I am having problems getting fuel i believe. I have replaced everything but the injectors so that is my next step. However, it is idling very low, couple hundred. Could this be related or is a completley new problem. Thanks for your help in advance.
have you tried adjusting the throttle cable at all???
I know after I did my mpfi swap on my old dx I had to becuase when I took the throttle cable off the si donor car I was using I had to deadjust it big time, when I put it back on my car I adjusted it to what I thought would be alright, but when I started it up it was idleing really low too, I readjusted it and reset my idle speed with the idle speed screw on the throttle body(your manual will tell you how to do this or search on HT its all over)
It just sounds to me like your starving your engine of air.......
