DOHC Cam Timing
Old Feb 29, 2004 | 05:32 AM
hlhneast's Avatar
Default DOHC Cam Timing
I have an 88 2.0 Si. When I try to set the cams at No. 1 TDC as indicated by the scribed marks on the cam gears, the valve train on both cams starts to load making it necessary to wedge the cam to keep it at TDC. Is this normal? TDC should have no load on it correct? I mean how else would you adjust the valves? What is the problem if the cam gears do not line up? Have they spun? HELP!
mouab18c1
32
Aug 3, 2011 06:00 PM
sayanything
Dec 21, 2010 06:36 PM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
hlhneast
Mar 1, 2004 08:54 PM
hlhneast
Feb 29, 2004 05:25 AM
