Intermittant CEL D16Z6
Old Feb 29, 2004 | 02:29 AM
E-brake or Handbrake's Avatar
Default Intermittant CEL D16Z6
Car:
1994 Ex Cp D16z6 5spd
Notes:
CEL comes on SOMETIMES when driven hard & on freeway with A/C on.
Goes away when engine turned off.
ECU isn't throwing codes.
I've had this problem for quite sometime where the CEL comes on intermittantly. This problem occurs very rarely at times when its driven hard & cruising on the freeway with the air conditioning on.
Most days when it's driven hard, there won't be a sign of the CEL coming on at all. The CEL comes on probably 3 out of 10 times when I'm cruising on the freeway. I've checked for codes but without a luck finding one.
If anyone has any information or suggestions, please let me know. Thank you in advance.
Old Feb 29, 2004 | 06:39 PM
Default Re: Intermittant CEL D16Z6 (EJ1Z6)
Bump for an answer.
Old Feb 29, 2004 | 06:45 PM
kingSfit's Avatar
i dont know sorry
Old Feb 29, 2004 | 07:26 PM
Default Re: (Bunz)
Does anyone know any information or have suggestions for me?
Bump for the evening.
Old Mar 1, 2004 | 02:34 PM
Default Re: (EJ1Z6)
I guess it takes longer for a tech-related thread to get answered than those "hey look at my ride" threads.
bump for 2nd day.
Old Mar 1, 2004 | 03:01 PM
Turbo E's Avatar
check for codes before turning motor off?
Old Mar 1, 2004 | 03:26 PM
2lua's Avatar
do you have header? sounded like your o2 getting lazy=slow respond.
Old Mar 1, 2004 | 10:10 PM
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">check for codes before turning motor off?</TD></TR></TABLE>
I've always thought you could only check CEL with the engine in the on position but not turned over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">do you have header? sounded like your o2 getting lazy=slow respond.</TD></TR></TABLE>
Yes I have a header. I replaced the o2 a few months back, I'd say approximately 5 months prior.
Any more suggestions?
Old Mar 5, 2004 | 08:39 PM
Default Re: (EJ1Z6)
Bump for any last thoughts. Thanks to all who replied.
kyang03
Mar 6, 2014 07:31 PM
b20acura
Nov 16, 2011 07:20 PM
crazyjetsfan22
Jan 12, 2008 08:54 PM
disposable
Aug 16, 2005 05:35 AM
deviant1
May 1, 2004 01:54 PM
