ITR JDM momo hub?
Old Oct 14, 2001 | 09:16 PM
redline's Avatar
Default ITR JDM momo hub?
Were can i get one??
Old Oct 14, 2001 | 09:23 PM
t's Avatar
t
Default Re: ITR JDM momo hub? (redline)
You can get one when you buy a JDM momo steering wheel. It is built into the steering wheel.
Old Oct 15, 2001 | 07:14 AM
Benjamin Tang's Avatar
Default Re: ITR JDM momo hub? (t)
which wheel? srs or non srs? if it's non srs, then it is part of the wheel as mentioned. if it's srs it's bolted on, but the hub ordered new from honda japan is very expensive. and no momo dosen't have it.
Old Oct 15, 2001 | 04:27 PM
redline's Avatar
Default Re: ITR JDM momo hub? (Benjamin Tang)
it would be none srs. I am looking for a hub that will work will a normal momo wheel on gen3 teg that the horn will work with out messin around with it. I thought i read i while ago that the JDM hub would work but i guess i was mistakin. I guess i am better off the just buy the srs ITR one then!
Old Oct 15, 2001 | 06:34 PM
t's Avatar
t
You still have to mess around with the horn with a Non-airbag wheel. The back of the JDM steering wheel hub is exactly the same as a regular momo hub.
BTW, if you get the JDM non-airbag wheel (and even if you get the regular momo hub, as the back is the same) you should also get the JDM ITR lower steering column cover or there will be a big hole where the Airbag cable reel use to be. Check this out on ebay.
http://cgi.ebay.com/ebaymotors/aw-cg...item=596765427
Old Oct 16, 2001 | 07:06 AM
the srs itr hub only works with the srs wheel. the wheel spokes on the non-srs wheel are welded to the hub.
natman316
Apr 13, 2011 10:26 PM
dutchman5
Feb 7, 2006 08:30 AM
92TypeR
Feb 19, 2005 12:29 PM
jonas
Feb 4, 2004 08:17 AM
