Will SI harness work in a HF
Old Feb 28, 2004 | 10:51 PM
markgo's Avatar
Default Will SI harness work in a HF
I was wondering will it be easier to get a SI, instead of rewiring the stock HF harness and if so is there a big wiring difference in the HF body with the SI harness?????
Old Feb 28, 2004 | 11:33 PM
Frederz's Avatar
Default Re: Will SI harness work in a HF (markgo)
i got a modified harness that will work for you email me @ frederz@aol.com if interested!!!!!!
Old Feb 29, 2004 | 04:16 AM
NCchris's Avatar
The Si harness won't plug in to the large round connector by the passenger shock tower. Plugs slightly different. If you are doing a swap, use the HF harness. Unless you are doin a H22 or something, the mods are simple. Tell us what you are doing and we might be able to help more.
chris
Old Feb 29, 2004 | 03:17 PM
jlicrx's Avatar
the Si engine harness will plug right into the HF chassis harness, but it won't work - all of the wires are in different locations in the connectors - if you are doing a swap, the wiring changes would be the same for either the HF or the Si
Old Feb 29, 2004 | 03:37 PM
-16V-'s Avatar
Default Re: Will SI harness work in a HF (jlicrx)
While we are on the subject.
I heard some people talking about modifying a 90-91 si wiring harness to fit a 90-91 dx. Because every thing is there buy that plug on the drivers side shock tower is different. Could u just do something to that plug to make a si harness work on a dx?
It that possible instead of doing a mpfi swap, and messing with the wire mess?
Old Feb 29, 2004 | 04:05 PM
jlicrx's Avatar
Default Re: Will SI harness work in a HF (-16V-)
well, you probably could do it if you had enough time - the DX has 14 wires in that connector - the Si harness only has 8 wires - obviously, some of the 14 wires on the DX go somewhere else on the Si (some are not used, like tandem valve) - the DX has the ignitor wire in that connector - also the radiator fan relay - why bother - converting DX is actually simple
Old Feb 29, 2004 | 04:12 PM
crx_ef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the Si engine harness will plug right into the HF chassis harness, but it won't work - all of the wires are in different locations in the connectors - if you are doing a swap, the wiring changes would be the same for either the HF or the Si
is their a diagram like that for the crx sir?
Old Feb 29, 2004 | 06:13 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the Si engine harness will plug right into the HF chassis harness, but it won't work - all of the wires are in different locations in the connectors</TD></TR></TABLE>
my bad, i knew thew were different somehow
K20AllMotorEF8
Feb 11, 2012 11:38 AM
crx89backedout
Jan 14, 2010 03:36 AM
awdlaser1
10
May 10, 2009 01:29 PM
lemongreenhatch
10
Dec 12, 2004 10:11 PM
got v-tec
May 17, 2004 07:06 AM
