toda valve springs, and head gasket....
i am planning on getting the toda valve springs, and head gasket.... but they only make it for the type-s and i drive a ep with k20a3, my question is if the valve springs and the head gasket fits on my a3 head? thanks for helping out... P.S. i know that the type-s valve springs can be use on the a3 head so.... thanks again
You don't need toda valve springs if you drive an SI. Those valve springs are meant for 9000 rpms, which you won't reach in your SI. I'm not sure if they gasket will fit, but if it says type S model only then there is your answer.
I've heard that the valve springs and head gasket do fit, but there's no need for it in an ep. There has been no issues with valve float because we can't hit a high enough rpm....even with Hondata. Put the money towards something else.
nsx-Animal
Sep 24, 2001 08:18 PM
