How do i paint rims?
Old Feb 28, 2004 | 07:56 PM
civicb18turbo's Avatar
Default How do i paint rims?
i'm sorry i have no access to posting this in the appearance forum but i do have an 91 civic this was my last resort. Well i have HX rims and i wanted to paint them black, i know i can't just coat it with black paint so i was wondering if anyone could inform me with the correct way. thank you in advance
Old Feb 28, 2004 | 08:09 PM
BLT2FLY's Avatar
Default Re: How do i paint rims? (civicb18turbo)
This is the way they should be done for best results:
First sandblasted and primed. Painted by gun not by a can from some bodyshop supplier and than finally clear coated to make sure the paint does not chip. Brand new rims.
Old Feb 28, 2004 | 08:21 PM
mugen92acintls's Avatar
Default Re: How do i paint rims? (BLT2FLY)
If you don't have alot of money or access to a sand blaster and you want them painted quick, use index cards between the rim and the tire and use a high temp laquer paint. as long as you laquer the paint will stick. If your rims are corrodded /rusted then consider sanding first.
Old Feb 28, 2004 | 08:32 PM
Default Re: How do i paint rims? (mugen92acintls)
high temp lacquer paint? how would you put the paint on? thanks guys for helping out
Old Feb 28, 2004 | 10:00 PM
91hatchcivic's Avatar
i wouldnt listen to the above posts...
give the wheels a light scuffing so the paint sticks.. either take tape and cover up the wheel, or take index cards and put them in between the wheel and tire, but i couldnt get this to work, so its easiest to put tape right where the wheel meets the rubber. Get a sandable primer, spray on like 2 medium coats, then sand smooth with fine sandpaper . Then get your paint, I highly suggest using dupli kolor or plasi coat paint, You will need like 2 cans. Spray light coats , lets dry , spray another coat until its to where you like it. Let them dry and put them on. heres my transformation:
from rice :
to somewhat good:
the shitty wheels actually looked decent, then didnt have to worry about it cause i sold it.
Old Feb 29, 2004 | 07:43 PM
PA MATT's Avatar
Default Re: How do i paint rims? (91hatchcivic)
being aluminum wheels....wouldnt sandblasting pit the wheels?
Old Feb 29, 2004 | 08:04 PM
manson's Avatar
Default Re: How do i paint rims? (ebpG2)
just clean them with a high pressure wash. then dry with a cloth to get any excess dirt or water off. wait till completly dry and then prime and paint. i actually didn't prime my wheels and i haven't had any problems.
just paint them.
Old Feb 29, 2004 | 08:11 PM
Default Re: How do i paint rims? (mansonclubpuir)
[QUOTE=mansonclubpuir]just clean them with a high pressure wash. then dry with a cloth to get any excess dirt or water off. wait till completly dry and then prime and paint. i actually didn't prime my wheels and i haven't had any problems.
just paint them.
Old Feb 29, 2004 | 10:58 PM
turbohf's Avatar
i had a great idea on this the other day: of course scuff up and clean the wheels, then apply that tire shine **** to the tires, then ****** paint away! let it all dry up for a day or whatever and hose off the tires then your set cuz paint wont stick to the treated tires
Old Feb 29, 2004 | 11:58 PM
Project91CRX's Avatar
it's easy... Just dont paint them at all...
Old Mar 1, 2004 | 07:22 AM
Default Re: How do i paint rims? (turbohf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohf &raquo;</TD></TR><TR><TD CLASS="quote">i had a great idea on this the other day: of course scuff up and clean the wheels, then apply that tire shine **** to the tires, then ****** paint away! let it all dry up for a day or whatever and hose off the tires then your set cuz paint wont stick to the treated tires </TD></TR></TABLE>
this works but it gets messy. you can also use any kind of vasiline , but its easiest to just use paper
Old Mar 3, 2004 | 06:36 PM
sirminder's Avatar
CIVICB18TURBO = MAMBAJUNKIE = UPBEATJUNKIE
GOES BY THE NAME OF
XAVIER/HOWARD TRAN
2187 DAHLIA COURT
SAN JOSE CA 95133
OTHER EMAILS ARE
upbeatjunkie@hotmail.com
nartdrawoh@comcast.net
bboyabserd759@hotmail.com
IP ADDRESS
67.161.16.213
I SENT HIM $250 FOR HX WHEELS AND HAS NOT RESPONDED
HE ALSO TOOK $310 FROM ANOTHER HT MEMBER FOR THE SAME HX WHEELS
$40 FROM YET ANOTHER HT MEMBER FOR A SHIFTKNOB
THOSE RIMS ARE THE ONES THAT HE ALREADY SOLD TWICE SO FAR
Old Mar 3, 2004 | 06:46 PM
variablevalve's Avatar
Default Re: How do i paint rims? (sirminder)
uber scammer!
yea im the guy that lost 310...
Old Mar 3, 2004 | 06:47 PM
bardo's Avatar
stole my $$ too..sent him money never answered
Old Mar 3, 2004 | 07:08 PM
CrX-To-Tha-Max
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">CIVICB18TURBO = MAMBAJUNKIE = UPBEATJUNKIE
GOES BY THE NAME OF
XAVIER/HOWARD TRAN
2187 DAHLIA COURT
SAN JOSE CA 95133
OTHER EMAILS ARE
IP ADDRESS
67.161.16.213
OWNED
Old Mar 3, 2004 | 07:14 PM
sirminder's Avatar
Default Re: How do i paint rims? (CrX-To-Tha-Max)
I JUST KNOW YOU ARE NOT TRYING TO BE HUMOROUS WITH YOUR LITTLE "OWNED" REMARK.
Old Mar 3, 2004 | 07:35 PM
onebadwankel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt listen to the above posts...
Listen to him. I have painted 5 sets of rims and the way he has described is the best way imho. It may take a few extra hours, but its well worth it to get a perfect finish that will last on the rims. As far as paint goes, i have always used the Duplicolor brand wheel paint from Autozone, that stuff is amazing! Dont forget to pickup a can of duplicolor wheel clear paint as well, makes the finish look a bit nicer.
Old Mar 3, 2004 | 07:46 PM
CrX-To-Tha-Max
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">I JUST KNOW YOU ARE NOT TRYING TO BE HUMOROUS WITH YOUR LITTLE "OWNED" REMARK.</TD></TR></TABLE>
it came out wrong. i intended the guy that screwed all of you to be "owned" by you posting his info.
Old Mar 3, 2004 | 08:02 PM
do this to the scammer --&gt; https://honda-tech.com/zerothread?id=786870
Old Mar 4, 2004 | 05:48 AM
WhatThaFrig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">do this to the scammer --&gt; https://honda-tech.com/zerothread?id=786870</TD></TR></TABLE>
That is the greatest thing I think I've ever read
Old Mar 4, 2004 | 06:48 AM
bardo's Avatar
guess whos getting caught 2dayyyyyyyyyyyy (civicb18turbo)
Old Mar 4, 2004 | 06:56 AM
wickedEFguy's Avatar
Default Re: How do i paint rims? (bardo)
easiest and cheapest way in my eyes is to get a can of aircraft remover to get rid of the old finish on the HX wheels, sand them down so you don't have any pits, primer it. Now when the primer is finished you can either use a rattle can to paint them and get it looking good if your careful plus a coat of clear coat or have a paint shop paint them.
That I think it's probably the cheapest and best looking
Old Mar 4, 2004 | 09:22 AM
95civicracer's Avatar
not trying to be an *** but if you search there is a huge right up on it.
NuHon_2001 Accord
Jul 20, 2008 07:48 PM
aznxguyx89
Aug 30, 2007 08:49 PM
zer0zer0 TypeR
May 29, 2002 07:28 AM
