just got crx... need little info in the engine swap
Old Feb 28, 2004 | 07:42 PM
CRX_GUY_123's Avatar
Default just got crx... need little info in the engine swap
hey... i just bought a 89 crx si that already has mounts for b series engines... i just needed to know if all b series will fit in because i dont know about the wiring and all about the obd1 and obd2 and that stuff... so what engines will i be able to fit... im thinking about a b16a1... thanks
Old Feb 28, 2004 | 08:22 PM
BLT2FLY's Avatar
Default Re: just got crx... need little info in the engine swap (CRX_GUY_123)
Any B-series engine will fit. 1.8non vtec would be the easiest swap. Anything else is going to need extra wiring for the vtec control. B16 is by far the most populr that I have seen on this site.
TYPEROLLER#420's Avatar
all b sriies will fit w a cable transmision
check sig for a mount kit for cheep
you can use hydro w a special mount kit
you want a b16 a w cable trans swaper
Old Feb 28, 2004 | 08:25 PM
DC 2's Avatar
Stick with the first gen b16a b/c its obd-0 like your crx, then you only need to add 4 wires to ecu.
Old Feb 28, 2004 | 10:25 PM
1hotcivicSi's Avatar
hey post pics of this ....... or do u have any pics??? i think i kno u from sumwhere
Old Feb 29, 2004 | 07:13 AM
Dwight Schrute's Avatar
Default Re: just got crx... need little info in the engine swap (1hotcivicSi)
dont swap. build your d16a6. im going to build mine for high compression. nothing like built sohc non vtec kicking some ***.
Old Feb 29, 2004 | 09:02 AM
McDade's Avatar
Default Re: just got crx... need little info in the engine swap (drewthomas14)
http://www.hasport.com
check out Tech > Swap Options on their top menu bar
Old Feb 29, 2004 | 02:51 PM
Default Re: just got crx... need little info in the engine swap (McDade)
k thanks
Old Feb 29, 2004 | 04:08 PM
Rywire's Avatar
check out my site, its in the sig, b16 swap
franky343
Dec 22, 2011 07:14 AM
crx_si_mike
Classic Hondas
Jun 23, 2009 05:53 AM
uNbrokeN
Feb 28, 2004 07:33 PM
RyanAutry
Feb 16, 2003 07:22 AM
jonnyc
Dec 20, 2001 01:46 PM
