why wont his vtec work?
Old Feb 28, 2004 | 05:05 PM
ricekiller1's Avatar
Default why wont his vtec work?
my buddy just had a b16 put in his crx and when the vtec kicks in it feels like its hitting rev limiter. the car wont allow him to go past 4500 rpms??? whenever vtec hits. he has the correct ecu. the car seems like it should be pulling a lot harder even out of vtec. please help
Old Feb 28, 2004 | 05:10 PM
Redline130's Avatar
Default Re: why wont his vtec work? (ricekiller1)
Are there any codes on the ecu? Check engine light?
Old Feb 28, 2004 | 05:26 PM
Default Re: why wont his vtec work? (Redline130)
he used to have a crank poss. sensor code but he got a new distributor and its gone. he has a idle sensor code being thrown but i wouldnt think that has anything to do with it.
Old Feb 28, 2004 | 05:31 PM
Redline130's Avatar
Maybe he has an automatic ecu.
Old Feb 28, 2004 | 05:32 PM
ThefirstPACT's Avatar
maybe the car is going into limp mode! When it goes into limp it wont let the car go over a certain rpm! So you wont damage the vehicle.
Old Feb 28, 2004 | 05:47 PM
Redline130's Avatar
Default Re: why wont his vtec work? (ThefirstPACT)
Yeah, but usually when the ecu goes into limp mode, there is usually a CEL or code on the ecu.
Old Feb 28, 2004 | 05:54 PM
could it be a bad ground, oil pressure or vaccum lines?
Old Feb 28, 2004 | 06:05 PM
i have a jdm gsr ecu, with that work just to see if the ecu is the problem?
Old Feb 28, 2004 | 06:22 PM
Redline130's Avatar
Not unless you have your car wired for OBD1 or 2 which ever that GSR ecu is. Go ahead and double check the grounds and wiring. Also, pull the VTEC solenoid off, and inspect the screen on the solenoid. Sometimes the screen gets clogged with gunk and doesn't allow sufficient oil to get to the VTEC mechanisms.
Old Feb 28, 2004 | 08:35 PM
krazie1's Avatar
BANNED
that is his problem right there
just by his facts
I had that problem two weeks ago
and they charged me at the dyno it fix that
just for assuming it wasn't that
but worth it
and if it goes into limp mode like that
obd0 don't give u that code cuz there ain't a code for that
so fix that and hold on for vtec!!!!!
Old Feb 28, 2004 | 08:39 PM
xtrafastcivic's Avatar
Default Re: why wont his vtec work? (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">that is his problem right there
just by his facts
but worth it
so fix that and hold on for vtec!!!!! </TD></TR></TABLE>
right where !!!!?????!!! hahaahahah
just say the problem or quote it please ...
are you talking about ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes the screen gets clogged with gunk and doesn't allow sufficient oil to get to the VTEC mechanisms.</TD></TR></TABLE>
Old Feb 28, 2004 | 09:01 PM
HOW DO I FIND OUT IF IT IS GOING INTO LIMP MODE? WHAT ARE THE MOST COMMON REASONS FOR THIS OCCURING?
Old Feb 28, 2004 | 09:34 PM
91civicEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">he used to have a crank poss. sensor code but he got a new distributor and its gone. he has a idle sensor code being thrown but i wouldnt think that has anything to do with it. </TD></TR></TABLE>
what the hell is an idle sensor
speed_demon018
47
Jun 22, 2009 08:05 PM
epak
16
Aug 6, 2006 07:03 PM
JBirch_97Prelude
Jun 29, 2006 03:29 PM
red-eg6
Sep 19, 2005 02:55 PM
Prelude Styl
Mar 20, 2004 08:13 PM
