Clarification please...
someone please give me a little clarification.
are a(n) intake manifold and throttle body the same thing or is the throttle body the piece inbetween the intake and the intake manifold?
also
are a(n) exhuast manifold and header(s) the same thing
thnx for the replies in advance
also
you are correct on the exhaust manifold and header being basically the same, for the intake look at the engine, the intake manifold is what connects to hte block on the firewall side. in the order the air travels I believe it goes, filter, intake, throttle body, intake plenum, intake manifold, block, exhaust manifold, cat and back
ok i did go look and i see the other smaller piece that is bolted on to the intake manifold where is the plenum at ?
the intake manifold consist of the large piece on the firewall side that takes air from the intake and seperates it into
the four cylinder's right?
