Im pretty sure this is bullcrap but.......
Old Feb 28, 2004 | 04:40 PM
I Gotta Question's Avatar
Default Im pretty sure this is bullcrap but.......
I dont know this for sure but this guy told me that the C5 block has Titanium rods and misc. titanium parts on it. I dont think this is true. As far as I know all a C5 is, is a C1 w/ a B16 head. Am I right or is this other guys right, or are we both way off?
Old Feb 28, 2004 | 04:52 PM
Spoon Spec EK's Avatar
Default Re: Im pretty sure this is bullcrap but....... (I Gotta Question)
He's wrong. Your also wrong.
The C5 bottom end is DIFFERENT from the c1 bottom end.
Old Feb 28, 2004 | 05:01 PM
nightrider's Avatar
a B18C5 is a B18C1 with B16 head? you guys are both horribly wrong.
Old Feb 28, 2004 | 05:02 PM
nfn15037's Avatar
Default Re: Im pretty sure this is bullcrap but....... (Spoon Spec EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon Spec EK &raquo;</TD></TR><TR><TD CLASS="quote">He's wrong. Your also wrong.
The C5 bottom end is DIFFERENT from the c1 bottom end. </TD></TR></TABLE>
The blocks are 100% the same, the internals are different.
Old Feb 28, 2004 | 05:05 PM
nightrider's Avatar
check out http://itrsport.com and look under technical.
you too spoon EK.
Old Feb 28, 2004 | 05:29 PM
Default Re: Im pretty sure this is bullcrap but....... (nightrider)
Rods are constructed of special high-strength steel to withstand higher rpm's and are still lighter than GS-R connecting rods
High-pressure die cast piston crown has been reshaped to increase compression ratio from 10.0:1 up to 10.6:1
The changeover point between low lift and high lift in the Type R is 5700 rpm (compared to 4400 rpm on the GS-R)
Thanks got all the info I needed.
Jerseyfan
Jun 10, 2008 01:21 PM
delsoldrew
23
Jun 19, 2007 12:47 PM
o0Jash0o
10
Jun 7, 2006 10:20 PM
CivicSwapper
Dec 10, 2003 08:11 AM
Spooled1.6L
Jul 17, 2003 10:19 AM
