rear balance shaft sprocket
Old Feb 28, 2004 | 11:53 AM
amb4081's Avatar
Default rear balance shaft sprocket
There are two marks on the rear balance shaft. There is a dot and there is a notch. The Haynes manual shows a pic that has the notch lining up with the dot on the block. However, the only way I can insert a drill bit to lock the rear balance shaft is when the dot on the sprocket lines up with the dot on the block; NOT the notch. Can someone help me? This is quite urgent! Thanks.
Old Feb 28, 2004 | 12:19 PM
amb4081's Avatar
Default Re: rear balance shaft sprocket (amb4081)
Can anyone HELP? This is rediculous. I don't understand why Honda sees the need for pairs of timing marks per balance shaft sprocket. It just creates more opportunity for confusion.
Old Feb 28, 2004 | 06:10 PM
GreenD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amb4081 &raquo;</TD></TR><TR><TD CLASS="quote">However, the only way I can insert a drill bit to lock the rear balance shaft is when the dot on the sprocket lines up with the dot on the block; NOT the notch.</TD></TR></TABLE>
thats where it needs to be, even if the marks dont line up. i had the exact same issue when i changed the belt. i lined up the mark and the shaft wouldnt lock, i locked the shaft and the marks were off i figured it was one or the other so i tried it w/ the marks lined up, and i could feel it wasnt right when i drove the car. so i re-did it w/ the shaft locked and it runs perfect. hth
Old Mar 2, 2004 | 10:27 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: rear balance shaft sprocket (GreenDestiny)
the balance shaft turns at twice the speed of the crank. so you have to just keep turning the gear until you can get it lined up.
gort
Feb 5, 2017 02:34 PM
tweaked.crx
Nov 6, 2012 06:55 PM
dge330
May 21, 2008 08:56 AM
bajramx
Honda S2000
Jan 23, 2008 05:28 PM
Icemanxxxv
Oct 17, 2005 09:48 AM
