Need help on motor swap!!
Old Feb 28, 2004 | 11:51 AM
uNbrokeN's Avatar
Default Need help on motor swap!!
I have a 91 Honda CRX, I was wondering if a SiR motor ( b16 ) will fit right in without changing the axels and all that crap.... can I just swap the motors in and out with no problem? will it fit perfect???
Old Feb 28, 2004 | 12:06 PM
96-EJ6 B18C's Avatar
Default Re: Need help on motor swap!! (uNbrokeN)
Please search this has been coverd pleanty of times.
» Search Results
Your search for b16 swap returned 156 results.
Old Feb 28, 2004 | 02:50 PM
99EKhatch's Avatar
u think thos little d-series mounts can handle a b16?
to answer your question.....if the engine is obd1 wiring isnt that bad and your going to need new mounts and linkage too
Old Feb 28, 2004 | 07:33 PM
jlicrx's Avatar
for B16A1 into 91 CRX, you will need engine, transmission, axles, shift linkage, mount kit and ECU - if your CRX is HF, you will need to swap knuckles/hubs for ones from DX or Si - if your CRX is DX, you will need to convert wiring from DPFI to MPFI - you will have to wire up the VTEC - you will need header
dc2itr617
Jun 24, 2009 08:15 AM
jdmnerd32
Dec 15, 2008 12:18 PM
theRiby
Apr 30, 2004 11:09 AM
trexb16
Nov 5, 2003 03:16 AM
