civic si rear pad install help
Im doing a rear disc conversion with a set of 99-00 civic si rear disc setup
i bought 99-00 rear pads from honda and one of the pads has a silver tab that sticks out and one does not.
i cant figure out where pad goes behind the rotor and which one goes in front, nor can I figure out if the tab should be at the top or bottom of the caliper
any help would be deeply appreciated
http://www.hondaautomotivepart...SK%29 I cant post pic's to save my life but here is a something that should help, the last time i changed my 00 breaks was a while ago ..........but the tabs should be up and sticking out
Modified by 95sihb at 8:34 AM 2/28/2004
yeah the "TAB" goes on the inside of the rotor and the should be on the bottom.. and so you know that "TAB" is the break snesor.. once your pad gats worn to that level it gets rubs on the rotor making a screeching noise.. so you know you gotta change your brakes... before you ruin your caliper
gabbernaut
Aug 23, 2012 04:20 PM
gabbernaut
Aug 18, 2012 12:29 PM
gabbernaut
Aug 13, 2012 12:21 PM
