clock install?
Old Feb 28, 2004 | 07:13 AM
mikecivichb's Avatar
Default clock install?
I tried to do a search but couldnt find anything. Well I have a clock out of a ef and I wanted to insall it into my dx hatch. I think there is a yellow, white/Blue, red/black, and ground. Which wire goes where? Any help would be welcomed. Thanks
Old Feb 28, 2004 | 08:01 AM
91civicDXdude's Avatar
the dx has the plug for the clock attached to the factory delete plate
Old Feb 28, 2004 | 12:39 PM
Default Re: (91civicDXdude)
whats the delete plate? Is it the plate that is in the spot wright now?
Old Feb 28, 2004 | 01:15 PM
Redline130's Avatar
Default Re: (mikecivichb)
Yes it is, there should be a pre-wired connector to plug into the clock.
Old Feb 28, 2004 | 01:21 PM
Default .
thanks
Old Feb 28, 2004 | 04:50 PM
willymac22's Avatar
Default Re: clock install? (mikecivichb)
hey how did you get the panel off? where the clock goes? I have a clock but no clue on how to get that part of the dash off in order to install it.
Old Feb 28, 2004 | 06:35 PM
xtrafastcivic's Avatar
Default Re: clock install? (willymac22)
flat head :D
Old Feb 28, 2004 | 07:16 PM
highhopes's Avatar
Default Re: clock install? (XtraFastCRX)
I've done this exact thing to my car, and luckily for you its really easy. The center vent has to come out...this can be done with
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX &raquo;</TD></TR><TR><TD CLASS="quote">flat head :D </TD></TR></TABLE>
a flat head screw driver. CAREFUL not to break the old brittle plastic. Once you get the vent out, turn it around and there should be two screws to get that "delete plate" off. In the guts of your dash, you should also see a wire with the plug on the end of it. Plug it into the clock, screw everything back in, pop the vent back in the dash and you have OEM time...
Old Feb 28, 2004 | 07:30 PM
1CiViC1's Avatar
Default Re: clock install? (highhopes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highhopes &raquo;</TD></TR><TR><TD CLASS="quote">I've done this exact thing to my car, and luckily for you its really easy. The center vent has to come out...this can be done with
did exactly what highhopes stated in my STD hatch. OEM time
JDMJUNKIEMONKIE
21
May 9, 2011 10:21 AM
nauticalstar80
23
May 20, 2009 05:18 PM
civic89si666
Aug 4, 2007 06:20 AM
CivicRaping
Mar 5, 2005 06:56 AM
gogs1021
Audio / Security / Video
Jan 19, 2005 10:18 AM
