Hf ecu for Si
Old Feb 28, 2004 | 07:09 AM
Sampsonite987's Avatar
Default Hf ecu for Si
I am swapping my hf(b15b1) for a si(d16a6) I need to know if my stock ecu will work for the si, or do I need a different one. Thanks I searched but found nothing for HF's.
Old Feb 28, 2004 | 07:40 AM
HamiltonRex's Avatar
Default Re: Hf ecu for Si (Sampsonite987)
change the ECU man, you will see more significant power gains.
Why go to the trouble of a engine swap and not run the proper computer.
-Eric
Old Feb 28, 2004 | 07:49 AM
Tyson's Avatar
it will work fine until you can get your hands on a PM6 of PG7 for the A6. youll still be limited by the programming of the HF ecu, but it will work.
Old Feb 28, 2004 | 08:00 AM
91civicDXdude's Avatar
will throw a cel for EGR valve. Also ive seen it make the idle surge,plus you will have a 5400 rpm rev limit, but it will work in a pinch
Old Feb 28, 2004 | 09:43 PM
Default Re: (91civicDXdude)
Yeah, Im not going for power. I just need to swap this motor in for now, my d15 is blown. Whats the d15 ecu, a pg6, I forget. Anyway, I might look for the proper ecu if I can find it for cheap.
Old Feb 28, 2004 | 09:46 PM
Tyson's Avatar
Default Re: (Sampsonite987)
PM5 is DX ecu. not sure if it will work with MPFI since its just DPFI, whereas HF is also MPFI which is why it will work with the Si.
Old Feb 29, 2004 | 03:12 AM
civicwagonman's Avatar
Default Re: (Tyson)
the hf one is a pm8.
Old Feb 29, 2004 | 04:10 AM
NCchris's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">PM5 is DX ecu. not sure if it will work with MPFI since its just DPFI, whereas HF is also MPFI which is why it will work with the Si.</TD></TR></TABLE>
As Tyson sez, the DX ecu will not run a MPFI (2) injectors vs (4). The HF ecu will run any MPFI application, although not the way it is supposed to be run. It will crank and run my B18, I tried it! Prolly very lean and with a very low fuel cut (5400 rpm) or so. I would get the correct ecu for my engine if I were you!
HTH
chris
Old Mar 2, 2004 | 10:58 AM
Default Re: (NCchris)
Well, if I planned on running the engine for a long period of time, I would change the ecu. I just dont know if it is worth it to spend the money for a temporary deal.
Old Mar 2, 2004 | 12:50 PM
DC 2's Avatar
i have an PM6 I just pulled, i just started my swap. Pm if interested.
Old Jan 10, 2020 | 04:08 AM
David Hudgens's Avatar
So can you (with stock motor) swap the ecu in an hf to a si ecu
50stanger
Mar 19, 2012 06:48 AM
Ofeargall
Classic Hondas
Jan 29, 2012 07:10 PM
88crxdxfastwhip
Feb 1, 2006 06:28 PM
joey1320
43
Nov 15, 2002 12:47 PM
crx(gator)
Oct 16, 2002 02:38 PM
