options for a grinding ys1 trans
Old Feb 28, 2004 | 05:43 AM
NVMYSi's Avatar
Default options for a grinding ys1 trans
I have a third gear grind when I am shifting in high rpm's, what are my options for rebuilding? I hear cable trans parts are hard to get. I don't want to convert to a hydro unless it is my only option. The car is a 90 crx with a B16.
Old Feb 28, 2004 | 02:39 PM
acy76's Avatar
Default Re: options for a grinding ys1 trans (Don'tNeedV8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontNeedV8 &raquo;</TD></TR><TR><TD CLASS="quote">I have a third gear grind when I am shifting in high rpm's, what are my options for rebuilding? I hear cable trans parts are hard to get.</TD></TR></TABLE>
Not at all. The YS1 internals are the same as newer hydro internals. Everything should be easily obtainable from Honda. Just look up parts for a 92-93 integra (GSR if you have the GSR gearset, as there are differences).
Old Feb 28, 2004 | 06:35 PM
NVMYSi's Avatar
Default Re: options for a grinding ys1 trans (acy76)
so the "guts" from a newer hydro trans will fit in the cable trans case?
Old Feb 28, 2004 | 08:51 PM
fearless_dsm's Avatar
yes..not sure about gsr or ls but 99-00si and type r will fit...
Old Feb 29, 2004 | 07:19 AM
Patch's Avatar
Default Re: options for a grinding ys1 trans (fearless_dsm)
Or, you could just rebuild your YS1. Get bearings, blocker rings, and syncros from a 92-93 US Integra GSR.
Old Feb 29, 2004 | 07:44 AM
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontNeedV8 &raquo;</TD></TR><TR><TD CLASS="quote">so the "guts" from a newer hydro trans will fit in the cable trans case? </TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm &raquo;</TD></TR><TR><TD CLASS="quote">yes..not sure about gsr or ls but 99-00si and type r will fit...</TD></TR></TABLE>
GSR will fit just fine. LS too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">Or, you could just rebuild your YS1. Get bearings, blocker rings, and syncros from a 92-93 US Integra GSR.</TD></TR></TABLE>
Probably the easiest. Just bear in mind that the YS1 stamp does not necessarily mean you have a GSR gearset. Most YS1s are LS gearsets. Get the parts for the right gearset, especially if you've got 3rd gear problems - your shift fork will need to match the synchro sleeve.
Old Feb 29, 2004 | 10:27 AM
NVMYSi's Avatar
so swap in a hydro gearset and add a type-r final drive, lsd and I would be good as new. very nice... where is the best place to buy these parts? I have never had to do anything to a trans other than a clutch and lsd.
Old Feb 29, 2004 | 03:16 PM
acy76's Avatar
You'll need to do a little grinding to get enough clearance for the GSR/ITR diff carrier if you do swap the internals. Try this site
http://www.acuraparts247.com/s...e.jsp
for some decent prices on parts. Or try Len on H-T or Bert-O on EF1.
gsr_b20b
Sep 4, 2012 05:04 PM
'91DA
Mar 31, 2010 03:47 PM
goldenhatch13
Sep 9, 2008 04:11 AM
2 0 3
Dec 10, 2006 08:19 AM
NFJohn
May 27, 2004 05:40 PM
