Identify theses sensors plz!
Old Feb 28, 2004 | 05:11 AM
Cyberdx16's Avatar
Default Identify theses sensors plz!
Hey can you guys please tell what sensors go to these plugs? thx
I think i have this plugged up right but i want to know what sensor that is
Is this the egr lift sensor? if not what goes there?
or is this the egr lift sensor?
I have no clue wtf this is!!
Old Feb 28, 2004 | 06:09 AM
3gLudeH22A's Avatar
Default Re: Identify theses sensors plz! (Cyberdx16)
ok im goin to give it a shot.......
pic 1 is right....thats the egr valve.
pic 2 i think you are correct.
pic 3 looks like map sensor.
pic 4 i cant remember...fast idle or thermo????
Old Feb 28, 2004 | 12:22 PM
ludeR917's Avatar
Default Re: Identify theses sensors plz! (3gLudeH22A)
pic 4 looks like the fpr?
Old Feb 28, 2004 | 12:55 PM
lenn's Avatar
no, pic 4 is the IAC... i cant remmeber what the name of the stupid sensor is though... btw.. thats a nasty tear in the fuel pressure regulator vacume hose... wow.. i really didnt contribute to this thread at all huh? lol
Old Feb 28, 2004 | 01:08 PM
ludeR917's Avatar
Default Re: (lenn)
so, in pic 4 the fpr is in the picture btw. and to the left is the intake air control valve.
Old Feb 28, 2004 | 02:15 PM
DW's Avatar
DW
Default Re: (ludeR917)
egr valve
fast idle valve(i think)
map sensor
IAC sensor(i think)
David
Old Feb 28, 2004 | 02:27 PM
aeolus's Avatar
1. EGR valve
2. That sensor was put on the jdm engines,the us engines don't have it.it connects to the fpr and the other end is connected to the intake manifold.From what i remember,its supposed to control fuel during warm up...You don't need it,you can just connect the vacuum hose from the fpr to the intake manifold directly.
3.MAP sensor
4.Idle Air Control Valve (IACV)..looks like its not plugged in. You can disconnect the number seven hose from the fpr and dissconnect the number 12 hose from that black solenoid valve and connect it to the fpr.
Old Feb 28, 2004 | 09:17 PM
Cyberdx16's Avatar
Default Re: Identify theses sensors plz! (aeolus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">1. EGR valve
3.MAP sensor
can u explaine 2 and 4 to me a bit better? i dont get what u mean by number 12 hose?
Old Feb 28, 2004 | 09:39 PM
v4lu3s's Avatar
RTFM
1. egr valve with lift sensor on top of it
2. evaporative purge control solenoid
3. map sensor
4. iacv
Old Feb 28, 2004 | 11:04 PM
Cyberdx16's Avatar
Default Re: (v4lu3s)
do i need the evapaorative purge control solenonid connect to the harness or ecu??? im running the p13, so will it throw a code? Also what do i plug to the iacv?? thx!
Old Feb 28, 2004 | 11:29 PM
aeolus's Avatar
Default Re: (Cyberdx16)
maybe im not reading it right,but the other hose that connects to the black sensor,it has a number on it,it looks like a number 12.The hose with the hole in it has a number seven on it.
Old Feb 28, 2004 | 11:47 PM
Cyberdx16's Avatar
ok i think i figured it out now. so what i have to do to connect the iavc and evaporative purge control solenoid is hook up vac. line 12 which is located under the i/m on the intake Air bypass control solenoid valve to vac line 7 (which use to be connect to the evaporative purge control solenoid to the fpr) and T it off to the fpr and i/m plug located where the evaporative purge control solenoid vac. line went. is this right? and now i dont have any vac lines going to the evaporative purge control solenoid and i dont have to hook anything to the iavc
this helped out a lot!
* oh yeah where do i hook up vac line 8 to??? i dont think the civic has a intake control diaphragm, or was it found on the air intake tubing?
Modified by Cyberdx16 at 9:07 AM 2/29/2004
Old Feb 29, 2004 | 12:59 AM
aeolus's Avatar
see how the manual shows how the fpr line is coonected to the intake manifold???Thats what you need to do.the civic wont have a intake control diaphragm,so forget about that one.When i said #12 hose,i wasn't refering to what the helms says,i was refering to the pictures,but like i said,it looks like a number 12 hose,but i can't really tell from the angle it was shot at.What ecu are you gonna use?
Old Feb 29, 2004 | 04:49 AM
Cyberdx16's Avatar
Default Re: (aeolus)
im running the p13. so i dont have the hook up vac line to anything, so should i completly cut it off or should i just let the vac line as it is and suck air?
Old Feb 29, 2004 | 01:34 PM
aeolus's Avatar
if you connect the hose right to the fpr,there shouldnt be any open vacuum lines.
samson_420
Jun 7, 2011 06:03 PM
sIcWiTiT
Sep 4, 2006 05:39 AM
sIcWiTiT
Sep 3, 2006 04:00 PM
thrty8street
Audio / Security / Video
Sep 1, 2004 07:37 PM
