Wings West W type Rear Lip Fitting with modded exhaust (1994)
Old Feb 28, 2004 | 02:38 AM
xunkn0vvnx's Avatar
Default Wings West W type Rear Lip Fitting with modded exhaust (1994)
I have a 1994 Honda Accord and was interested in purchasing the w type rear lip for my car. I currently have a knock off tanabe g power muffler. Will I have to modify the rear lip in anyway to make the muffler fit ?? I.e. Cut a hole for the exhaust ??? Thanks...
Old Feb 28, 2004 | 05:18 AM
Mike813's Avatar
Default Re: Wings West W type Rear Lip Fitting with modded exhaust (xunkn0vvnx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xunkn0vvnx &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1994 Honda Accord and was interested in purchasing the w type rear lip for my car. I currently have a knock off tanabe g power muffler. Will I have to modify the rear lip in anyway to make the muffler fit ?? I.e. Cut a hole for the exhaust ??? Thanks...</TD></TR></TABLE>
did you try emailing wingswest? or where ever you bought the lip from?
from most pics ive seen theres no slot for the exhaust, but i could be wrong.. check the picture thread above, alot of people has that lip on their accords, pictorial view might help ya out..
Old Mar 1, 2004 | 05:07 PM
Oxygen's Avatar
Default Re: Wings West W type Rear Lip Fitting with modded exhaust (Mike813)
there is no slot for the exhaust, you need to goto pepboys, or autoparts and get bigger exhaust bushings (rubber things) so it will let the exhaust sit lower so it doesnt rub the bottom of the rear lip ...
Old Mar 2, 2004 | 03:54 AM
dcaccord's Avatar
My 96 accord WW rear lip came with a slot cut out for the exhaust. However, it wasn't large enough and the top of my DC exhaust tip touched the lip in the slot and eventually started to melt it. I just cut the slot bigger with a dremel. Looks good and no more problems. A spec sheet that comes with the lip tells you that you need a min. 1/4" clearance between the lip and exhaust.
Civic Racer X 7
10
Dec 13, 2006 01:44 PM
torqueless
Aug 23, 2005 10:37 AM
EARLdaSQUIRREL
Sep 1, 2003 06:19 PM
