OEM rear sway bar question.
Old Feb 27, 2004 | 11:25 PM
EG8R's Avatar
Default OEM rear sway bar question.
Is there a difference between a Civic and a CRX rear sway bar?
For the 88 DX people that have mounted an OEM rear sway bar.... How did you go about doing it?
I did try a search but was not satisfied with what I had found.
Thanx
Old Feb 28, 2004 | 08:49 PM
OEM_Spec's Avatar
Default Re: OEM rear sway bar question. (skelly ed6)
Bump for you!!!!
Old Feb 28, 2004 | 09:50 PM
b16_madman's Avatar
I took all the stuff that you use to mount the sway bar and where it would usually bolt to the frame, we welded onto the frame.
I'm using a crx bar, it's a hair bigger. mm's of a difference, don't member how much.
I've had it for quite a while now, so it's workin fine for me.
Old Feb 29, 2004 | 09:40 AM
EG8R's Avatar
Default Re: OEM rear sway bar question. (B16_madman)
Anyone else have input?
Modified by skelly ed6 at 4:06 PM 2/29/2004
Old Feb 29, 2004 | 03:28 PM
EG8R's Avatar
spaazm
Apr 13, 2014 10:17 PM
jaje
Oct 7, 2009 09:57 AM
GloomyX
Suspension & Brakes
18
Mar 29, 2007 07:42 AM
lowbOOsted
Dec 5, 2005 05:37 AM
