failed emissions, high THC and NOx - analysis please?
the car is a 91 sentra xe, w/ 129k miles. bone stock, dad just took it in today and it failed. what could be the culprit? has high thc and nox .
type/standard/reading/results.
thc / 1.20 / 1.95 / fail
NOx / 3.00 / 5.38 / fail
CO / 30.0 / 7.2 / pass
CO2 / N/A / 335.9 / N/A
its hard to read the sheet in the pic, does your car have an egr valve? i cant look up specs right now since its like 4 am az time. anyway if your car does have and egr start there. high HC's and high nox's can come from a bunch of different things and being that i cant listen or look at the car start with the egr(if there is one). then look into vacuum leaks and lean misfires. hope this helps.
too much THC? shoot, i'd leave the car running with the garage door closed.
maybe old cat?
dirty intake filter.
check all your emission stuff to see if its working. did the guy tell you what was wrong with it? he should've told you what you need to do to fix it.
maybe old cat?
since it's stock... I would say, a tank full of good gas, a tune up, and possibly a new cat. Cat's are normaly only good for 80K to 100K mi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">run rich= fuel unburn, bab o2, leaking injectors, worn out spark plugs, dirty airfilter, misfire, plugged pcv...ect needed a tune up???</TD></TR></TABLE>
are you saying its rich? well CO is low so its not running rich, NOx is usually from bad cat. and/or bad egr, HC can be from bad spark plugs, wires, bad dizzy cap.
well, looked at the car and did a mini tuneup. plugs were really old, bolts holding the cap on were rusted to hell, and cap contact points had alot of buildup. swapped a new rotor, cap, plugs, and put some civic stock ign. wires on er, and a new fram filter. awaiting the bottle of guaranteed to pass emissions formula, hopefully it passes.
ooowww oregon DMV ive been there about 30 times....
no im not joking i finaly just got a swap, hahaha.
PM me if you need a tips/tricks on how to pass.
im too lazy and buzzed to read your post right now
tayone415
22
Jan 22, 2014 10:22 PM
