hayne's lied, chilton's lied
i just redid my own timing belt after installing one following a book that caused my car to run like ****. ***(98 ek with b18b1)*** in the books they tell you that "up" arrows on cam gears are parralle. well they're not! the intake side leans a bit more to the front than the exhaust side. maybe its just my car but i highly doubt it. now my car drives like a million bucks.
I'm not shur about the B18b1 but doesn't it have the little drill holes to line it up. You put two small dril bits in them and your cams should be lined up.
if this is a thread to hate on haynes im down!
i just put in a new dizzy and haynes was tellin me that my firing order is 1234. so i did that and car wasnt started go figure... i check my helmes manual and it says 1342 try that out and vrooom!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 »</TD></TR><TR><TD CLASS="quote">i just put in a new dizzy and haynes was tellin me that my firing order is 1234. so i did that and car wasnt started go figure... i check my helmes manual and it says 1342 try that out and vrooom!!!</TD></TR></TABLE>I did the same thing once.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed »</TD></TR><TR><TD CLASS="quote">I'm not shur about the B18b1 but doesn't it have the little drill holes to line it up. You put two small dril bits in them and your cams should be lined up.
yeah, my b16 has the same thing.
</TD></TR></TABLE>yeah, my b16 has the same thing.
autoluder
Sep 22, 2009 04:31 AM
Intercooler
17
Oct 14, 2005 07:53 PM
mitsuman
Mar 28, 2004 02:17 PM
