noob: whats the easiset way 2 pull my motor out!
The easiest way to pull your motor is to pay someone else to do it. That takes no work at all.
Seriously. you have to lable both the motor and the wiring harnes as to what came off where. Rent, Buy, Borrow or steal a hoist. unbolt a lot of stuff. Unplug even more things.
You do need a manual if you need to ask this question, seriously. It will keep you out of serious trouble.
Step one: Get a hoist
Step two: unhook any engine/tranny mounts and vacuum lines
Step three: pull it out, tranny and all, from the top.
A hoist isnt needed. You can take off the front sub frame and wheels. disconnect the wire harness, fuel lines, throttle and shift cables, axles, and cooling system (dont forget teh heater hoses) and anything else that stays in the car like A/C and pwer steering. Then lower the car till the brakes are touching the ground blast off the motor mounts and let it fall 1-2 inches to the ground. Raise vehicle as high as possible and have 2 friend lift it a little more. Its not heavy with no motor. Then pull in out from under and your done. If you think dropping it on the ground is a bad idea put an old tire on the ground but thats higher that youll have to lift the car. Good luck.
a plasma torch
or park the front of it on the train tracks
seriously though loosen all your motor mounts discontec all connectors, throttle cable, fuel line, radiator hoses and a tree and a chain hoist work very well, or just rent a engine hoist from orellys or auto zone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 »</TD></TR><TR><TD CLASS="quote">A hoist isnt needed. You can take off the front sub frame and wheels. disconnect the wire harness, fuel lines, throttle and shift cables, axles, and cooling system (dont forget teh heater hoses) and anything else that stays in the car like A/C and pwer steering. Then lower the car till the brakes are touching the ground blast off the motor mounts and let it fall 1-2 inches to the ground. Raise vehicle as high as possible and have 2 friend lift it a little more. Its not heavy with no motor. Then pull in out from under and your done. If you think dropping it on the ground is a bad idea put an old tire on the ground but thats higher that youll have to lift the car. Good luck.</TD></TR></TABLE> wont that **** up the rotors?
that works good we do it all the time lol but i would rather have an engine hoist..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regime »</TD></TR><TR><TD CLASS="quote">ya know whats better then a hoist... A TREE... yeah... ive done it... stop laughing at me.... damn it i said stop.
Yes but have you ever had the tree branch brake with the motor attached to it..
</TD></TR></TABLE>Yes but have you ever had the tree branch brake with the motor attached to it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
well....most people would take a 4x4 and nail it to the branch and the base of the tree like a crossmember. but if your brave enough....or have trees the size of house, go for it. be safe
</TD></TR></TABLE>well....most people would take a 4x4 and nail it to the branch and the base of the tree like a crossmember. but if your brave enough....or have trees the size of house, go for it. be safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing »</TD></TR><TR><TD CLASS="quote">
This was a while ago.. From now on I use a cherry picker to pull it out..
</TD></TR></TABLE>This was a while ago.. From now on I use a cherry picker to pull it out..
This may not be the easiest way, but I couldn't locate an engine hoist to rent and I couldn't buy one b/c I had not way to store it.
Take the head off first. Get a couple strong friends and lift out the block and transmission. To put it in, do the opposite. It takes a little while longer to do it in pieces like that. And, you have to replace some stuff, like the headgasket, and others misc parts, but, you should do that anyway.
Just an alternative method though. I've taken out three engines doing it this way.
forget a hoist, look at this thread... plywood, allll plywood
https://honda-tech.com/zerothread?id=760664
you might want a helmet though
ucanstore acherry picker under a bed, just unbolt it!!
good to know your not breaking trees and smashing toes any more
I got skill.. I can drop it from a tree and it will fall right into place under the hood..
</TD></TR></TABLE>I got skill.. I can drop it from a tree and it will fall right into place under the hood..
grimace007
May 23, 2007 05:40 PM
