Where can i find b16/crx axles???
ok i was looking for some b16-ef axles, cause these retarded integ axles are shitty. but i wasnt looking to spend 4-500 bucks on some, im on a little more of a budget. anyone know where i can find some? the same as the 90 integra axles. dont even know if this is possible but let me know.
Modified by 4inspeed at 4:06 PM 2/27/2004
what kind of transmission?
Heres my post on what axles to use for J1 tranny
https://honda-tech.com/zerothread?id=773532
most likely u are having a problem with the drivers side, right?
thats cause u probably have the midshaft that requires the use of the 88-89 integra axle ends used with the 90-91 LS axle shaft. this would be the same axle that the si-r uses which is unavailable here.
need more info also
need more info also
no i have a 90 crx si with a s1 tranny, the 90 teg axles work, but they are a little bit longer then i would like, they fit, and they work, but im not building cars just so it "works" ya know? i want it to be right. this may be a stupid question, but does anyone make 90-93 teg axles, just a little shorter? i know its a longshot but i will never know unless i ask. i searched for about an hour and a half the other night, googled it and jeeves'd it. couldnt find much exept for hasports, and enjo's axles.
im not being cheap, i just dont have the cash..... and with rent and other bills 4-500 dollar axles dont sound as important
. they are about a full inch(yes a little less) longer then the SiR axles i had..... of course those wouldnt work....
oh well, i will stick with integ axles for now. im just kinda picky. thanks for your help
. they are about a full inch(yes a little less) longer then the SiR axles i had..... of course those wouldnt work....oh well, i will stick with integ axles for now. im just kinda picky. thanks for your help
pnwjdm
Dec 23, 2012 08:57 PM
VtecKiDD
Dec 29, 2005 09:45 AM
Kasper.
Jan 31, 2004 12:28 AM
