Starting problem
Old Feb 27, 2004 | 02:20 PM
AzntstyleZ's Avatar
Default Starting problem
My crx was running fine until i got home and tried to start it again after about 5 mins and it wont start. Im not even getting any power. I checked the battery, it was good, but the alternator is going bad. The car should still start but i dont kno whats wrong. please help
Old Feb 27, 2004 | 02:22 PM
I3ackfire's Avatar
Default Re: Starting problem (AzntstyleZ)
Change the alternator, and check your engine grounds.
Old Feb 27, 2004 | 02:30 PM
AzntstyleZ's Avatar
Default Re: Starting problem (I3ackfire)
Shouldn't i be able to start the car with a bad alternator?
Old Feb 27, 2004 | 03:31 PM
AzntstyleZ's Avatar
car still not starting
help!
Old Feb 27, 2004 | 04:03 PM
BLT2FLY's Avatar
The car will not start if your altenator has gone. Did you ever notice your battery light on while you were driving. This is the sign to change the alternator.
Old Feb 27, 2004 | 06:30 PM
hatchboy88's Avatar
Default Re: Starting problem (BLT2FLY)
your car will start just charge the battery it will olny last for a half a day or so
Old Feb 27, 2004 | 06:31 PM
hatchboy88's Avatar
Default Re: Starting problem (hatchboy88)
depends if you have your lights and or radio on
Old Feb 27, 2004 | 06:33 PM
hatchboy88's Avatar
how long it will last
Old Feb 27, 2004 | 06:43 PM
EF9Dreams's Avatar
pull code from ECU.... or ... check ignition systems and fuel system.... ( Distributor,Fuel Pump, Starter....ETC..)
Old Feb 27, 2004 | 08:28 PM
blah13's Avatar
Default Re: Starting problem (EF9Dreams)
When you say not getting power do you mean no interior lights or anything comes on? If so clean up your terminals and the clamps, 200+grit sandpaper is perfect. Then start checking connections/grounds and fuses. Esp the 60 amp ones in your engine bay fusebox, dont remember exactly which one but check them all anyway.
Old Feb 27, 2004 | 10:50 PM
Kasper.'s Avatar
Default Re: Starting problem (blah13)
How do you know your battery is good what was the static voltage?(the voltage as it just sits there with nothing on and no load on the battery?)
ScalCG6
Mar 28, 2019 04:56 PM
RS'R'
Jan 9, 2007 06:49 PM
sckrx
Jun 20, 2006 03:53 PM
flatblk
Jun 9, 2005 09:41 PM
boosted k20
Jan 7, 2005 02:32 PM
