Jumping ECU's
Old Feb 27, 2004 | 02:06 PM
Vtec92Civic's Avatar
Default Jumping ECU's
We have an EMERGENCY situation here and we need some help.
my friends motor is fucked so we dropped in my 92 d16z6 motor in his 2000 civic ex. We were just informed that the obd 2's have a crank angle positon sensor which the obd1's do not have.
Is there a way to jump the ECU or put a switch on the sensor or even ground it off so that the ECU will not look for that sensor?
We need any and all possibilites here! Will his car fire up, and be dravable without that sensor? Please post up anything u can to help out!
Thanks!
Old Feb 27, 2004 | 02:16 PM
mattssi's Avatar
Default Re: Jumping ECU's (Vtec92Civic)
Why not just use the newer wiring harness and the newer distributor?
Old Feb 27, 2004 | 02:32 PM
Default Re: Jumping ECU's (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">Why not just use the newer wiring harness and the newer distributor? </TD></TR></TABLE>
I don't get it am I missing something?
Old Feb 27, 2004 | 03:24 PM
mattssi's Avatar
The cylinder postion sensor is in the distributor right? Use the newer ecu, and the newer harness, and the newer distributor on the d16z6! It will act as if it was the stock motor?
Old Feb 27, 2004 | 03:42 PM
no the sensor is down on the y8 block near the crank or crank pulley. We jsut noticed that today. I guess there is 2 sensors . . . one in the dist. to watch detonation or something, and one down below.
delsolo95
18
Apr 3, 2013 01:09 PM
BigbamaBen
Mar 17, 2013 12:09 AM
KrisGriz
Feb 14, 2010 01:00 PM
Si2See
Apr 19, 2008 02:39 PM
thumbtack
Dec 8, 2004 05:11 PM
