EF SI Tranny REbuild gone wrong.....
Old Feb 27, 2004 | 01:31 PM
xmd's Avatar
xmd
Default EF SI Tranny REbuild gone wrong.....
I recently tried my hand at rebuilding an SI tranny with DX gears....
From what I understood the DX and SI gear sets were the same its just the final drive thats different...
Well I **** the 2 trannys apart.... and tried to just put the dx main shaft and countershaft in the SI but it wouldnt work...
So i ended up putting the SI counter shaft in with the DX main shaft.
i turned the shaft.. switched gears before i put it back in. Everything seemed fine.
I put it all togeather and put it in and IT wouldnt go into reverse.. YEs the reverse gear is in the right way... it was very sticky and then after.. i rolled it down the street it would drive... sorta in the gears so i pulled it back up the hill when it went Brrr ZZZ POP and nothing now... i could rev it prety high and try to shift and i get a grind. it wont go into any gear....
Any ideas....
is the issue that i mixed the dx main shaft with the si counter shaft?
The DX counter shaft just wouldnt go into the si bearing.... the SI one would slide right in...
-x m d
Old Feb 27, 2004 | 01:47 PM
Driven's Avatar
Default Re: EF SI Tranny REbuild gone wrong..... (xmd)
my guess is probably how you put it together...but, since we don't know exactly what you did or didn't do... .shrugs.
Old Feb 27, 2004 | 03:49 PM
DC 2's Avatar
Default Re: EF SI Tranny REbuild gone wrong..... (Driven)
TTT
Old Feb 27, 2004 | 08:52 PM
Mideel25's Avatar
up
GreenBean
Sep 6, 2007 11:39 AM
DirtyD777
Feb 10, 2006 04:01 PM
JaHnAbOi
31
Sep 28, 2005 08:41 PM
CRX_Control
Jan 16, 2005 08:18 AM
DOHC_EF
Jul 13, 2004 06:06 AM
