head unit help....
Old Feb 27, 2004 | 01:22 PM
90hatchie's Avatar
Default head unit help....
i am about to install my head unit in my dx and i am gunna have extra wires from the head unit that werent anything obviously on the stock. so can i just cap these or do i really have to figure out where these go. this is the first time i have installed a hu so im not completley sure what to do. i have tried a search but they arent helping and i mean dont i just need to look at what wires are for what on each head unit and match them up occordinly right? any help would help its a sony HU in a dx, with a stock casset player.
Old Feb 27, 2004 | 01:36 PM
EF9Dreams's Avatar
Default Re: head unit help.... (90hatchie)
Go to Best Buy and get a wire harness...... then connect color to color............. Easy way
oh you didn't KNooooooooooooooW
Old Feb 27, 2004 | 01:39 PM
90hatchie's Avatar
Default Re: head unit help.... (EF9Dreams)
lol..... fine i guess i will do that. i just didn't want to have to if it could be done without one. yes im lazy and cheap
Old Feb 28, 2004 | 03:51 AM
EF9Dreams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90hatchie &raquo;</TD></TR><TR><TD CLASS="quote">lol..... fine i guess i will do that. i just didn't want to have to if it could be done without one. yes im lazy and cheap </TD></TR></TABLE>
You get much more respect towards your car if you do things the right way... plus if someone buys your car later down the road and wants to change the HU it makes it easier on them.... i had somebody cut my wires on my HU and it was a pain in the *** to change it
Old Feb 28, 2004 | 02:42 PM
90hatchie's Avatar
yea i know. i got one last nite and installed it. only problem now is i talked a guy at sony and he said i wouldn't need anything to mount it , it would just sit in the same place as the stock one, yet it doesn't so its just kinda siting there for now. i guess i gotta go to best buy tomarrow and see what i need.
Old Feb 28, 2004 | 08:37 PM
sleeperx's Avatar
You have to use the can "metal sleeve" that came with the head unit and put that in first, bend the metal tabs so that it stays in place, then you can slide that head into the can and the head will lock into the can. Make sure that when you wire your head units harness to the harness that you get from best buy ( should be a metra 70-1720) solder all your connetions and use heat shrink tubing as well. Then after all connets are made use zip ties to keep the harness clean and neat. Make sure that any wires not used on both the head units harness and the adpting harness are protected with heat shrink.
hope this helps
lmike6453
Jul 18, 2007 04:34 PM
capric1983
Dec 14, 2005 07:05 AM
IntegraLs97
Audio / Security / Video
Aug 24, 2005 11:44 AM
mamaboy
20
Apr 11, 2003 07:23 PM
