any problem w/ using a hf distributor w/ si ecu
Old Feb 27, 2004 | 12:41 PM
twin rex's's Avatar
Default any problem w/ using a hf distributor w/ si ecu
basically i did a sohc zc swap on my hf rex and it seems to start and run better w/ the hf ecu. i have an si ecu and im not sure why but once the car is warmed up it does fine but when i first try to start it it has trouble. so is there a difference between the hf and si distributor(i know there both 7 pin)? or is my si ecu bad?
Old Feb 27, 2004 | 01:39 PM
jedubz's Avatar
The HF and Si should work they are interchangeable.... Weird.
Old Feb 27, 2004 | 01:53 PM
boosh's Avatar
well, i'm sorta in the same boat as you. i swapped a 95 1.5L into my crx, and i had to use the obd0 dizzy, alternator, and injectors. i'm also running the SI ecu. I had no problem with the dizzy swap.
about your car having trouble starting, what do you mean? does the starter have to turn a bunch more times to get the motor going?
Old Feb 27, 2004 | 02:14 PM
green91's Avatar
i had no probs, both say pm6 on the magnet under the rotor
Old Feb 27, 2004 | 03:57 PM
twin rex's's Avatar
Default Re: (boosh)
before i had a starter on the car the si ecu would only start after like 5 min of push starting it and when it did start it would bog down when i hit the gas until it got warm but when i went back to the hf ecu it would bump start right away, and now that i have a starter it starts right up, with the hf ecu, i guess i should switch ecu's again and see what happens
CRX MASE
May 19, 2008 03:27 PM
lilhatch89
Aug 11, 2007 05:02 PM
rice a roni
16
Oct 8, 2006 09:49 PM
baked_beanz
Apr 4, 2005 09:41 AM
Tyson
Aug 10, 2004 12:50 PM
