compression stroke when re-timing crx?
Old Feb 27, 2004 | 12:09 PM
Project_ED8's Avatar
Default compression stroke when re-timing crx?
i'm trying to adjust my timing belt and it says to make sure TDC is on the compression stroke and my question is how exactly do i make sure its on the compression stroke and not intake? i'm guessing you make sure the distributor rotor is facing towards the #1 spark plug on the distributor cap? well thanks for any help. oh yea one more thing...on the camshaft where the timing belt sits...does the belt have to be exactly in the middle? because it seems that most of the timing belt is on the grooves...but just a little is sitting off to the side, like its not fully centered as it should be? ok thanks again...
~john
Old Feb 29, 2004 | 10:14 PM
SOHCrx's Avatar
Default Re: compression stroke when re-timing crx? (Project_ED8)
hey dont mean to jack the thread but ur from suisun so i wanted to say wussup to a fellow suisunER haha.. on and bump.
Old Feb 29, 2004 | 10:41 PM
undefinedcrx's Avatar
look at the cam gear. there should be marks on the face of it, like lines that were grooved into it. turn the cam gear so that the "up" on the face of the gear is on the top most part of the gear. from there, if you look at the bottom left hand side of the face of the cam gear, you should notice a line grooved into the face of the cam gear. there should be a plastic tab behind the cam gear that supposed to line up with this line, and when you line them up, it should be TDC Compression stroke. I've made the mistake before of timing it on the exhaust stroke, but the car runs nearly identical, just the cam is 180 off, or just completely backwards. i dont see what issues this may cause besides being harder to time.
Old Mar 1, 2004 | 07:51 AM
subgeniusdude's Avatar
Default Re: compression stroke when re-timing crx? (undefinedcrx)
Pull the #1 spark plug out and rotate your crank while feeling for pressure...not suction.Or you can place a long wooden dowel or something that *wont scratch or fall into the cylinder* while you're turning the crank and when it just reaches the highest point and stops moving,you're at TDC...but check your cam gear marks and make sure the rotor is pointing at the #1 plug wire just to be safe.
Old Mar 9, 2004 | 05:55 AM
Default Re: compression stroke when re-timing crx? (SOHCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCrx &raquo;</TD></TR><TR><TD CLASS="quote">hey dont mean to jack the thread but ur from suisun so i wanted to say wussup to a fellow suisunER haha.. on and bump. </TD></TR></TABLE>
haha whats up man! yea actually i'm over in "cordelia" but its called suisun so yeah what color is your hf? maybe i'll see ya around sometime! aight then...
Old Mar 9, 2004 | 05:56 AM
thanks for the help guys. yea i made sure the marks on the cam gear were all aligned...and felt for compression on the #1 spark plug...then i rotated the crank a couple times to make sure everything lined up and sure enough it did. thanks again
Old Mar 9, 2004 | 09:32 AM
tgreaves's Avatar
Default Re: (Project_ED8)
You mean how do you know if its the compression or exhaust stroke.. It doesnt matter since tdc is just where cyl 1 is a the top.. The crank turns 2 times to the cam turning 1 time..
Old Aug 25, 2004 | 05:00 PM
roydogg's Avatar
Default Re: compression stroke when re-timing crx? (subgeniusdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subgeniusdude &raquo;</TD></TR><TR><TD CLASS="quote">Pull the #1 spark plug out and rotate your crank while feeling for pressure...not suction.Or you can place a long wooden dowel or something that *wont scratch or fall into the cylinder* while you're turning the crank and when it just reaches the highest point and stops moving,you're at TDC...but check your cam gear marks and make sure the rotor is pointing at the #1 plug wire just to be safe.</TD></TR></TABLE>
I got #1 at tdc but my rotor is firing at coil 2. It's completely off by 180* .
Here's the link https://honda-tech.com/zerothread?id=969457
Any help would be gladly appreciated
T_bones
Aug 20, 2007 06:43 AM
todapower
Apr 11, 2006 01:42 PM
ham
Nov 16, 2004 04:49 PM
rice is nice
Jul 14, 2004 10:04 AM
Civic89
Oct 24, 2002 09:13 AM
