ls ys1 question
Old Feb 27, 2004 | 09:33 AM
hatched92's Avatar
Default ls ys1 question
the ls ys1 and gsr ys1 were the only tranny's from the 90-93 tegs right? was there another ls that had longer gears? also the 94 up ls was a y80 correct? oh and how many qrts do i need to fill the ls ys1?
Old Feb 27, 2004 | 09:38 AM
Sliced Beard's Avatar
Default Re: ls ys1 question (hatched92)
ys1 is from either gsr or ls
the gsr has a substantial difference in gear ratios than the ls
and the s1 is another tranny that was around in 92-93 but only in japan on the sir1. the ls tranny that is 94+ is a s80 and the gsr had either a s80 or y80 case and the itr uses a s80 case also.
your case holds about two quarts of oil. fill it per factory specs and you will be fine
Old Feb 27, 2004 | 09:45 AM
hatched92's Avatar
yeah well i'm picking up a ls ys1 tranny tonight and just wanted to check. i didn't know what the factory fill was.
Old Mar 1, 2004 | 07:22 AM
Default Re: (hatched92)
well just fill it until oil starts coming back out the fill hole and VIOLA perfect amount of tranny fluid
Old Mar 1, 2004 | 11:51 AM
Colin's Avatar
Default Re: ls ys1 question (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">ys1 is from either gsr or ls
and the s1 is another tranny that was around in 92-93 but only in japan on the sir1. .
this is wrong.
the sir1 is an 89-91 engine, and has the earlier version of tranny, such as a s1, y1, or j1. The sir2 has a hydro tranny since in 92 civics became hydro.
all 92-93 integras came with "ys1" trannies. Doesn't matter if its rs/ls/gs/lss/gsr..... the gsr trannies have the shorter gears. The 92-93 jdm xsi's also had short geared ys1's. And I believe the 92-93 jdm b18a equiped cars also had ys1's.
usdm 90-91 cars had a couple different trannies, but never a ys1. Some have a1's, and I believe some have s1's. y1's and j1's were available in japan, but I don't think in the us. Also, the s1 has a jdm version with short gears.
91EF919
Transmission & Drivetrain
May 18, 2009 06:51 PM
scspeed
Dec 9, 2007 09:56 PM
wizzards581
Apr 17, 2007 03:17 PM
94acurals
Aug 19, 2001 05:41 PM
