b16a2 in an 88 crx si questions....
ok, im getting a b16a2 that is obd1 and has a cable tranny. i am putting this into my 88 crx si. are there any websites that have info for this swap? i am going to get an obd0-obd1 harness for the swap. is everything else just plug and play? ok thanks.
hasport.com can help a little.. but let me ask you why do you want to convert to obd-1.. hell i just would get a 1st gen b16a manifold and stay with good ol obd-0 less codes.. less hassle wiring wise.. your rex has a cable tranny too.. another problem for the b16a2..obd-0 is the way to go for the b16a in the rex.. if you are going to convert to ond-1 and hydro trans.. **** i would get a gsr instead!!!
good luck though
good luck though
you can get that obd1 b16 to work.. you'd need an obd0 ECU (pr3/pw0) and obd0 Dist.
The IM can probably work, you may have to do some creative wiring, I know the MAP sensor wire might have to be lengthed to reach the TB (cuz thats where the MAP sensor is on obd1 and newer motors)
nomotor
Jun 17, 2004 07:23 PM
firstgenrex
Feb 17, 2004 03:11 PM
