Skunk2 vs. Crower vs. Comp Cams ??
Old Feb 27, 2004 | 05:16 AM
benci's Avatar
Default Skunk2 vs. Crower vs. Comp Cams ??
Please help !
I planing to replace the camshafts in my B16A1 DOHC Vtec.
What brand and modell is good for both street use and racing?
Which ones should I avoid?
I'm only intrested in US made camshaft (less expensive than japs.)
- Skunk2 stage2 (Vtec Duration 266in./262ex. @ .485/.466)
- Crower stage2 (Vtec Duration 246in./239ex. @ .050")
- Crower stage3 (Vtec Duration 257in./246ex. @ .050")
- Comp Cams 57300 (VTec Duration 260in./260ex. @ .050")
- Crane Cams ???
I'm aware of that all of the cams above require an upgrade of the
valve springs & retainer.
I'm going to use:
B16B pistons in my B16A which gives CR=11:1 (original is 10.2:1)
//Benci
Modified by benci at 3:06 PM 2/27/2004
Old Feb 27, 2004 | 08:27 AM
Sliced Beard's Avatar
Default Re: Skunk2 vs. Crower vs. Comp Cams ?? (benci)
crower measures their import cams in metric measurements same with skunk 2
Old Feb 27, 2004 | 09:34 AM
92b16aTurbo's Avatar
Default Re: Skunk2 vs. Crower vs. Comp Cams ?? (dirtyd463)
It also depends on what your goals are...turbo, motor, nos. They make a difference in the type of cams you wanna buy. I have a turbo, and next weekend I'm gonna put in some USDM ITR cams in. I hear they are good for B16a1 - the 1st gen b16a cams suck...
Other than that, I hear Skunk & Crowers are good. I had Crowers on my B18a (non vtec), and they worked well for me.
Good luck.
ramswood2000
25
Sep 20, 2010 11:49 AM
TopEndTuner
Aug 16, 2008 11:28 AM
blackccoupe
Feb 22, 2008 04:41 AM
VtecDA9
43
Oct 19, 2005 03:44 PM
skellator_thoj
14
Oct 4, 2002 04:42 PM
